DIY...iKONA's Badge/Wiper Delete Trim Installation
Old Mar 12, 2009 | 04:24 PM
theloxmyth's Avatar
Fit Gadget Freak
Exclamation DIY...iKONA's Badge/Wiper Delete Trim Installation
Panel is held on by white clips. Pull forcefully to remove trim panel.
I filled the remaining electrical connector with grease and wire tied it.
Remove factory trim...
Install iKONA's trim. Check fitment before tightening nuts! Fill connector with grease and wire tie!
Reset clips like so...
Reinsert pull...
The FIT badge comes off next!
Make sure not to over tighten nuts so the studs don't detach from panel.
Old Mar 12, 2009 | 04:31 PM
Fitcapo's Avatar
Nice job. You did what I was supposed to do awhile ago lol....
Old Mar 12, 2009 | 04:38 PM
iKONA636's Avatar
Lol noice writeup! Lovin the garnish hehe
Old Mar 12, 2009 | 04:42 PM
iKONA636's Avatar
If this thread helps you give him rep!
Old Mar 12, 2009 | 04:47 PM
theloxmyth's Avatar
Fit Gadget Freak
That's because YOU don't NEED the +REP!
Old Mar 12, 2009 | 09:43 PM
theloxmyth's Avatar
Fit Gadget Freak
Glad to help.
Worked well and looks gooood, too!
Old Mar 13, 2009 | 01:59 PM
GD3_Wagoon's Avatar
awesome write-up!
if there's enough interest in the grille that i've proposed, i'll be doing a write-up with the installation for that piece soon as it's delivered to my door
Old Mar 13, 2009 | 03:14 PM
theloxmyth's Avatar
Fit Gadget Freak
Thumbs up J...Let me know if you want any of these e-mailed!
J... and fellow FitFreaks!
These are today's pictures after washing (not drying) the car. Let me know which ones you want me to e-mail to you. PM e-mail to me, if you want to.
This VBP has got to be the worst color for water spots!
Craigster
Notice something else missing?
Old Mar 13, 2009 | 05:21 PM
Fitcapo's Avatar
Uhh you have no rear spoiler so assuming you are a base fit. Can't think of anything else that should be there after having the badgeless wiperless garnish.
Old Mar 13, 2009 | 05:28 PM
theloxmyth's Avatar
Fit Gadget Freak
Compare...
Old Mar 13, 2009 | 05:34 PM
Fitcapo's Avatar
Ohh your fit badge is gone. I just didn't even bother looking for it because there are soo many people without them and I haven't had one for the longest time.
Old Mar 13, 2009 | 05:39 PM
theloxmyth's Avatar
Fit Gadget Freak
Yeah, even though it was 35F when I washed the car, the sun really heated things up so I removed it and used GooBeGone to remove the adhesive!
Now people won't be able to tell what my "Fitster" is!
Old Mar 13, 2009 | 07:08 PM
secondspassed's Avatar
it looks like either the garnish sits a couple millimeters too high or the rubber seal needs to be pulled out from behind the top of it. every piece i've seen installed from iKONA looks like it has this issue, I'm not sure if it's something about his product or just an overlooked aspect of installation. anyone else see this?
Old Mar 13, 2009 | 07:57 PM
trancedsailor's Avatar
looks great! The write-up is a bit confusing but I'll read it over and over to try and get my thick head to understand everything lol
Old Mar 13, 2009 | 09:16 PM
theloxmyth's Avatar
Fit Gadget Freak
+100 REP for you, brother!
I tried to make the DIY flow, but I must not be THAT good at it.
Old Mar 13, 2009 | 10:03 PM
Idea: add a "Tools you will need" at the beginning of the DIY. Also, the 2nd pic wtf is that? Is that what's underneath the hatch window? I have to remove the whole back panel? That worries me lol
Old Mar 13, 2009 | 11:02 PM
iKONA636's Avatar
To answer seccondspassed qeustion. The rubber is most definatley pinched. Like I said I test fit every garnish and they fit perfectly on the test panel here.
thefit09
60
Feb 9, 2014 12:57 PM
SpoonFitGD3
May 1, 2011 11:03 PM
markwalter
Aug 25, 2010 07:46 PM
xonexlifex
Oct 21, 2009 01:55 AM
mikow
Jul 31, 2008 11:18 AM
