Spring Comparision
Old Mar 26, 2009 | 08:22 AM
  #141
HEMI-Fit's Avatar
Got it, Thanks!
Now to see if the struts will fit the OEM springs and maybe be legal for HS AutoX racing. The price is pretty high though, unless I can find another ePay deal...
Thanks again,
HF
Old Mar 27, 2009 | 08:52 PM
  #142
OCKC's Avatar
From: San Francisco(20+yrs)/Westminister(10+yrs), CA
Took some new pics:
Old Apr 23, 2009 | 10:45 PM
  #143
c.ase's Avatar
would you happen to know the drop and specs on spoon progressive springs?(in inches)...thanks
Originally Posted by ciburri
You are 100% correct rabbitron!
I did not think that further explanation was needed since I was talking about oversteer. Oversteer only comes to play during cornering.
Thank you for bringing it up kenchan. It definitely deserved to be explained in detail. My bad!
Progress is the choice to go with if you are not going to AutoX, Road race or take canyons like devil himself was chasing you. LOL! It will give you greatest cruising comfort with least bouncy ride as long as you are not carrying lot of cargo weight and/or 2-3 rear passengers. In that case pick a brand with higher rear spring ratio.
Here is the spreadsheet sorted by "front to rear stiffness ratio".
I find it easier to start from there for the sake of balance and then compare spring stiffness among manufacturers.
One thing I find amusing is that both Eibach and H&R refused to disclose spring rates considering both Eibach Pro Kit and H&R Sport Kit have identical drop! ROFL! Is it being manufactured in the same facility?!
Email me if you would like me to send you the spreadsheet.
Ivan
p.s. I wonder if picking softest front spring, stiffest rear spring and addition of Progress rear sway bar would make an impact on the drift competition? LOL! Just kidding!
Old Apr 24, 2009 | 12:48 AM
  #144
OCKC's Avatar
Fit F: 3.5kg/mm, R: 5.0kg/mm
Old Apr 28, 2009 | 10:37 PM
  #145
Kurse's Avatar
Still no spring rate for the h&r spring?
Old May 8, 2009 | 12:02 AM
  #146
fit-aficionado's Avatar
What an awesome thread guys! Thanks to everyone who put effort into helping others like myself with such great info and explanations!
Old May 26, 2009 | 03:57 AM
  #147
fitster's Avatar
anything on spoon springs?
Old Jul 18, 2009 | 11:15 AM
  #148
doughn's Avatar
which BRAND/MODEL of lowering springs has Better Ride (close to stock)
thanks
Old Jul 21, 2009 | 07:08 PM
  #149
TheImmortal's Avatar
thanks
closest to stock is....stock!!!
Old Jul 21, 2009 | 07:15 PM
  #150
Originally Posted by kenchan
also note that these are progressive rate springs...meaning, they have
initial and full compression rates and many variable rates in between.
those numbers are to be used only as a guide... there is no indication
whether those are initial or full or just averages.
if you see a rate like 500lbs, you know they are very stiff.
if you see 2 different rates from the same manufactuer then
you can tell which are stiffer as they probably (assuming)
used the same measuring method(s).
2 different rates from 2 different manufacturers.... you can only
guess.
mine r 560in/lbs rear , 448in/lbs front....linear
Old Jul 21, 2009 | 07:54 PM
  #151
doughn's Avatar
"close to stock ride" lowering springs... not stock!
anyway thanks
Old Jul 21, 2009 | 08:13 PM
  #152
EXWRX's Avatar
If you look at the rates, Progress is the smallest increase in rate, and keeps the same front/rear ratio as stock. It should ride the closest to stock.
Old Jul 21, 2009 | 08:17 PM
  #153
doughn's Avatar
thanks vmuch....for the help.
Old Jul 28, 2009 | 12:58 PM
  #154
1990hondahf's Avatar
Anyone have any stats on Zenn springs? I emailed a seller and got this back:
We have no idea and ZENN is no longer in business so there is no one to ask
Sean.
Old Aug 10, 2009 | 04:12 PM
  #155
Fitguy07's Avatar
I was thinking about the S.Techs cause I like the drop but not the spring rate, too stiff. I like the spring rate on the Preogress's but not enough drop. It seems like the Tanabe DF210's fall right in between. If I ever get springs, it will probably be those. They have the Tein Drop but a softer spring rate.
Old Nov 20, 2009 | 03:58 AM
  #156
Kurse's Avatar
all spring there are progressive?
Old Dec 11, 2009 | 04:05 PM
  #157
chivo_fit's Avatar
what springs should i get if i want the lowest drop i can get.. the ride is gonna be stiff?
Old Mar 1, 2010 | 11:57 AM
  #158
SS RICH's Avatar
Based on all the science of spring rates etc... can the techies out there state which spring they feel is best with the stock dampers. I was considering the swift or the teins
I dont have the scratch for a coil over system right now.
Old Mar 1, 2010 | 01:42 PM
  #159
Texas Coyote's Avatar
I am hoping like hell that Swift Mach Springs are the best. Minimal drop, lots of travel less coils to prevent binding..... I did the severe drop thing on a V.W. Rabbit many moons ago and really screwed that little car all up by doing so.... As soon as the weather is a little warmer I will put the Swift Machs on my Fit.
Old Mar 1, 2010 | 03:04 PM
  #160
SS RICH's Avatar
Cant wait to see how it turns out. let me know
