View Single Post
  #13 (permalink)
Old 05-17-2009, 02:38 PM
Moltisanti2009 Moltisanti2009 is offline
Moltisanti2009 should get some awardsMoltisanti2009 should get some awardsMoltisanti2009 should get some awardsMoltisanti2009 should get some awardsMoltisanti2009 should get some awardsMoltisanti2009 should get some awardsMoltisanti2009 should get some awardsMoltisanti2009 should get some awardsMoltisanti2009 should get some awardsMoltisanti2009 should get some awardsMoltisanti2009 should get some awards
You're from texas so I can understand why your fuel economy would go down. Anyone north of the mason dixon line will tell you their fuel economy improves in the summer because of warmer temps...even if they use the a/c. I see an improvement of probably about 5 mpg at the least.
Good thread, however. Still very appropriate if you want to max out your MPG in the summer.
__________________
2009 Honda Fit - Blue Sensation. Waiting for it to be delivered in mid-May. Fresh off the truck....Got here in early June...Absolutely LOVING it!
2009 Toyota Corolla S - Blue Streak Metallic...The Lady's
