View Poll Results: Which turbo kit?
T1R
13
46.43%
HKS
35.71%
Greddy
14.29%
custom
3.57%
Voters: 28. You may not vote on this poll
T1r, HKS, Greddy, custom?
Old May 24, 2009 | 12:55 PM
1990hondahf's Avatar
Question T1r, HKS, Greddy, custom?
Which is the most sensible(set up, cost, power etc) turbo kit and why?
Old May 24, 2009 | 04:00 PM
CamFit's Avatar
I think this issue has been beeten to death already.... but with the release of the greddy kit mabe a refresher would be in order.
i vote t1r, moste complete and no need for hks tuning shopp
Old May 24, 2009 | 04:41 PM
Originally Posted by CamFit
I think this issue has been beaten to death already.... but with the release of the Greddy kit maybe a refresher would be in order...
Indeed! The price of the greedy is not too bad....I can't wait to see how it compares.
Old May 24, 2009 | 09:59 PM
Im|Inside|Fit's Avatar
even though i have heard soo much that T1R is "THEE" best turbo kit ill still go for the HKS =)
Old May 24, 2009 | 10:11 PM
Spooling's Avatar
Go with the GReddy turbo kit, then customize the GReddy kit.
Old May 25, 2009 | 03:48 AM
kylerwho's Avatar
spoon fed
ok so here is the low down on the differant kits. they all share practically the same hardware aside from these differances.
t1r requires tapping into the oil pan and changing the injectors.
hks requires an official tuner for the piggyback ecu and a BOV. it is carb legal.
i have no knowledge of the greddy kit yet and you just need to track down all the parts for a custom one which is probably cheaper but way more work.
personally i would go with the t1r because it comes with bigger injectors so if you want to up the amount of boost you just need to retune and your ready to go.
this is all my personal opinion though.
Old May 28, 2009 | 04:30 PM
The Greddy and HKS are "plug and play" T1R is not. Also, the Greddy makes more power at 4.X PSI then the HKS does at 5.7 PSI...but the HKS is the lowest priced...I found it for just over $2700 shipped at: HKS - Turbo Kit - Bolt On - Nengun Performance
Sean.
Old May 29, 2009 | 05:27 PM
CamFit's Avatar
aside from the oil pan tap, t1r could be "plug and play" with simply AEM F/IC and boomslang harness.... and just sell the greedy e-mangle.. recoupe some money
thats the plan... 4me
If I had not been informed about the Aem F/ic fix for the lean closed loop problem, 4get the turbo.
as it turned out... forum's are a godsend... and boost is comming soon.
along with some other crap... soon.
JamesBizzle
Jan 24, 2012 09:26 PM
LaoSiFu
Jun 18, 2010 08:11 AM
fit4afit
20
Apr 29, 2010 07:41 PM
azkikersfit
Dec 25, 2009 08:15 PM
Combo_Turbo
24
Mar 28, 2008 06:00 PM
