HID kit not working right.
Old Apr 26, 2009 | 04:34 AM
kroze's Avatar
My passenger side HID light go on instantly as soon as I turn the light on.
My driver side headlight flickered and then slowly turn on.
Is this a sign that the ballast or bulb is bad & need of a replacement?
Old May 25, 2009 | 02:30 PM
hidextra.com's Avatar
how long have you have the HID? it looks like you need a new bulb.
if the hid is used for more than 3 years, i might be time to get new bulbs.
you can contact directly if you have issue with your HID system.
Old May 27, 2009 | 01:51 PM
ReeSpeed's Avatar
Ive got the same problem....One light goes on immediately and the other goes on, then dims...then brightens back up. After like 30 seconds they are both the same brightness so I dont mind.
Old May 27, 2009 | 05:11 PM
713_fit's Avatar
check connections
disconnect and reconnect
SOMETIMES it works
shake the ballast too
Old May 28, 2009 | 11:24 PM
chrisng's Avatar
hmm i had a similiar problem, but i htink its b/c i dind't put hte connections in securely enough. try that
Old May 28, 2009 | 11:27 PM
mzfitt's Avatar
bulb might be burning out i had that problem not to long ago
with mine the passenger one would stay white instead of turning blue
until one day it starting turning off & i would have to shut off my lights & turn them back on.. & then it just died out
so u might need to replace. cus i did that & they been working since
madtodaimax
Feb 26, 2014 04:22 PM
XenithXenons
47
Jan 9, 2011 07:56 PM
samwell
Jun 10, 2010 01:38 AM
kimo
Jun 17, 2008 01:13 PM
SoccaBoi
Oct 18, 2007 10:49 AM
