where to weld the wideband sensor?
Old May 27, 2009 | 04:36 PM
Spooling's Avatar
Where is the best location to weld the UEGO Wideband Controller? turbocharged engine.
and which route did you get the line into the cockpit.?
Old May 27, 2009 | 04:43 PM
Sugarphreak's Avatar
Push My Button
Past the O2 sensor location, lots of people put it in front and the heat from the turbo cooks it in a couple of weeks.
Old May 27, 2009 | 04:53 PM
Spooling's Avatar
Thanks for the fast reply
Would it be on the Testpipe or the B-Pipe?
Old May 27, 2009 | 11:05 PM
Spooling's Avatar
Ended up welding it on the horizontal section at the beginning of the B-pipe. The HKS kit's AFR is very boring. At idle, when the car is completely warmed up or during red light, the AFR is around 14.7-15.2. full/sudden throttle the number drops from anywhere around 12.6-13.5. i dunno if the numbers make any sense. i guess it's a pretty timid carb legal kit.
got my AEM F/IC in TODAY. waiting for boomslang harness.
Old May 29, 2009 | 01:30 PM
explosivpotato's Avatar
Yep, that sounds about like the AFR's you'd see in a CARB legal kit.
You wanna be at or around 14.7-15.0 in vacuum, or leaner if you wanna try a lean-burn cruise. Near 0 vac and in boost you ideally want to see your AFR smoothly decend into the mid or low 12s. Anything at or above 13 in boost makes me nervous, personally, but with a good tune I guess it's a possibility. The general rule is you CAN hurt things by going just a touch too lean, but it's pretty tough to do that by going too rich.
Old May 29, 2009 | 02:20 PM
daragez's Avatar
PM me if u needs assistance on your car ill introduce you to my cousin hes a good automechanic.budget can be discuss..
explosivpotato
38
Apr 27, 2010 12:11 PM
leonine
Mar 14, 2009 10:51 PM
Spooling
Feb 13, 2009 09:30 AM
Fitinside
Mar 26, 2007 09:54 PM
