fuel injectors
Old May 28, 2009 | 06:50 PM
Spooling's Avatar
fuel injectors
what size fuel injector should I get to push beyond 9 psi?
which brand?
DO I need special connector clips to install the injectors?
Thanks
Old May 29, 2009 | 01:21 PM
explosivpotato's Avatar
To support power you want to shoot for a flow size. Byeond that, things like brand really don't matter.
Get RC450cc injectors, those will do nicely for your goals with plenty of overhead. Make sure you get the Saturated (high impedance) injectors. I think there are clips required to make them fit your OEM harness. Clips came with my RC310s in my T1R kit.
Old May 29, 2009 | 03:50 PM
Spooling's Avatar
rc450 might be overkill for 8psi~10psi
im thinking RC 370cc saturated
Old May 30, 2009 | 04:40 PM
You can't hurt anything with injectors that are a little too big. 450s won't cause any issues idling, but injectors that are too small can cause big issues. Lower duty cycles tend to increase injector life.
That said, it probably won't make much difference so long as they can flow enough.
Old May 30, 2009 | 10:31 PM
Spooling's Avatar
+rep to you, explosivpotato
Old Jun 3, 2009 | 03:06 AM
Spooling's Avatar
Do i need to use spacers to run RC injectors? which clip to get?
honda style top? or just normal one?
Old Jun 3, 2009 | 03:33 AM
kelsodeez's Avatar
UNBANABLE
upgrade your fuel pump too if you are going over 9psi
Old Jun 3, 2009 | 05:09 AM
jagass's Avatar
I need to know this too...
Old Jun 3, 2009 | 01:27 PM
RC injectors will require a spacer for the fuel rail, in my experience. My assumption would be that Honda style tops would be necessary. Reference the emblem on your steering wheel for proof. (sorry, I had to).
I couldn't tell you exactly at this moment. I could take a look at my flow test paperwork from RC at home after work and see if it reveals anything.
Old Jun 3, 2009 | 07:24 PM
Spooling's Avatar
it's ok guys i figured it out.. it's really simple and i made it too complicated
in order to achieve 180-200whp, which is really 220-250 crank power. you will need four 370cc saturated injectors. SPACERS are included with the RC injectors.
Get the SL4-0370. It is the one for modern Honda's fuel rail (ie. rsx, civic etc).. then buy the OBD1->OBD2 clip, part number CLIP-HCC.
do not get the Honda Top Style RC injectors as it's for older Hondas with resistor boxes. newer hondas don't use resistor boxes as they use high resistence fuel injectors.
rep me
as im the first one to openly share non biased info.
Old Jun 4, 2009 | 03:38 AM
JamesBizzle's Avatar
where can we buy the BOD1->OBD2 clips?
Old Jun 4, 2009 | 09:23 AM
wheelspin's Avatar
Has no one tried S2000 injectors? They are 360cc/min and the stock fuel pump in 190lph. Best of all you retain OEM reliability and no walbro fuel pump whine. Also, you don't need injector clips...they're a honda part already. Stock s2000 put down around 190 whp which is around what most FI fits are putting down. I have a s2000 but I'm lazy and haven't got around to test fitting, that and pulling the fuel pump is a bit of a PITA to pull.
Last edited by wheelspin; Jun 4, 2009 at 09:26 AM. Reason: spelling and grammar pwns meh.
Old Jun 6, 2009 | 07:37 PM
artieman's Avatar
look into the acura rdx injectors
410cc and can be found for about $40 bucks each online new.
Old Jun 6, 2009 | 11:31 PM
Spooling's Avatar
that's good to know...
but... will the RDX injectors fit on the L15??
Old Jun 6, 2009 | 11:38 PM
you get some USED RDX injectors for around $50- $80.
Old Jun 6, 2009 | 11:40 PM
RSX injectors fit our cars, and I know that RDX injectors fit on RSX's... so my guess will have to be yes.
Old Jun 7, 2009 | 02:57 AM
kylerwho's Avatar
spoon fed
so it would be safe to assume that the k20/k24 injectors work for the l15a?
Old Jun 7, 2009 | 03:48 PM
artieman's Avatar
hence why i droped the hint to look into the acura rdx injectors
they have an excellent spray pattern and they are cheap...
Old Jun 7, 2009 | 03:57 PM
Spooling's Avatar
to use RDX(K23) injectors on RSX(K20s), you need clips from the Scion TC
how do u know that the normal k20's 310cc fits on L15?
Old Jun 7, 2009 | 06:57 PM
Type S 310cc's are a direct replacement. No need for additional clips BUT you're right bout needing clips for swapobg RDX's into RSX's
