check engine light on help please
Old Jun 8, 2009 | 11:40 PM
hondafitblue's Avatar
okay let me start with what went wrong i had no check engine light at first. but while my car was on i started to check my fuses because my ac compressor was not working i ended up fixing that problem but while i was pulling out fuses one fuse i pulled in the front made my car like idle and i quickly put it back. i then when to check to turn off my car and turn it back on and i seen a check engine light.
My friend had a scan guage and when he pulled out the codes this is what came up
evaporative emission system vent control circuit low
and
also
02 heater circuit bank 1 sensor
i don't know why these codes came up i never had a check engine light before...im trying to figure what should i do next... any advice??
Old Jun 9, 2009 | 08:58 AM
DaZ's Avatar
DaZ
you need a new oxygen sensor
Old Jun 9, 2009 | 10:24 AM
TekXoID's Avatar
First CEL can be caused by so many things in the fuel system like a bad charcoal filter or a loose gas cap/bad gas cap.
Second CEL is coming up because the oxygen sensor isn't working in a timely manner or at all...that usually means replacement, but whats your mileage? It may just be a wiring problem.
Old Jun 9, 2009 | 10:42 AM
spreadhead's Avatar
Did you clear the code with the scangauge, did it come back on?
Old Jun 9, 2009 | 12:06 PM
hey guys thanks for all the help im so glad its good now... guess what my friend misplaced a fuse and i had my cousin look at it he checked everything oxygen sensor and all that and last he went to the fuse box and seen there was a fuse missing.. i guess when my friend was trying to fix it he dropped a fuse..
thank god i knew there was nothing wrong with my car only when he started to miss with my fuses.
Old Jun 9, 2009 | 01:30 PM
TekXoID's Avatar
Glad you got it figured out! I thought it seemed a little early for a new O2, haha.
Old Jun 9, 2009 | 06:35 PM
comptrekkie's Avatar
@ TekXoID Where's my Chippy, ahh there's my CHIPPY!!
Stacie Kahns
Sep 28, 2017 10:46 AM
0021
Jan 21, 2016 09:00 AM
bjvalencia
Jan 30, 2012 09:26 PM
Velikimrav
Canada Fit Forums & Clubs
Apr 12, 2007 12:57 PM
hisame2332
Sep 21, 2005 07:30 PM
