p1157 Engine code .. HELP PLEASE!!!1
Old Jun 12, 2009 | 09:06 PM
redfit_pr's Avatar
whats up guys? well..this morning when i startup the engine the cel come in...i scan it and it show this code... p1157 Air Fuel ratio A/F (Sensor 1) line high voltage.... what i have to do? anyone with this problem? a friend told me that i have to replace the first o2 sensor... what do you guys say?
thanks.. juanpo..
Old Jun 13, 2009 | 01:30 AM
kylerwho's Avatar
spoon fed
just unplug the battery for 5 minutes and plug it back in and start up your car. this typically will reset the ecu and your code will probably go away.
are you running a cat delete? if so you might want to look into a mechanical o2 fix.
Old Jun 13, 2009 | 06:19 PM
redfit_pr's Avatar
i already do it.... chek engine come again... i think i need to buy a new o2 sensor...
Old Jun 13, 2009 | 07:31 PM
im the fit's Avatar
Im in the same boat the cheapest i found it for is $178 with shipping = ( dont use the car mine idle's super rich at 13.2 and accelerating and driving runs at 17 if afr if not not more I fixed it for now using the F/ic but we need that sensor.
Old Jun 14, 2009 | 01:13 AM
redfit_pr's Avatar
^^^ thats bad bro... i dont have any wideband gauge that show me how rich or lean i am.. i just dont push the pedal to hard..... i hate that she swallow a lot more of gas....
but where do you found it in that price?
Old Jun 14, 2009 | 01:52 PM
Carbuff2's Avatar
Just a note...don't be temped to go cheap on the o2 sensors. Use OEM or Denso brand.
Those who have gone to other brands have NOT been happy.... and usually end up replacing the sensor again anyway.
Old Jun 15, 2009 | 11:08 PM
im the fit's Avatar
::-- wUnder Car Parts --::
Old Jun 15, 2009 | 11:19 PM
redfit_pr's Avatar
thanks man... this is the one ? right?
234-9060
OE Style Oxygen Sensor $161.12 Oxygen Sensor;OXYGEN SENSOR (NIP);Front ; Eng Code: L15A1; Years: 2007-2007;Qty Per Vehicle:2;
Old Jun 16, 2009 | 02:50 AM
die_lawn's Avatar
i had that same thing on my accord. just gotta buy a new OEM one cause the non OEM ones just don't seem to work as good
mdcljhe
Feb 7, 2018 09:18 PM
xenocide702
Jul 5, 2016 02:38 PM
bobblebob13
Jun 19, 2013 01:34 AM
BansheeScratch
Nov 17, 2011 01:31 PM
07FitSBOM
May 17, 2008 09:09 PM
