M&M Honda REAR lower arm bar?
Old Jun 22, 2009 | 10:56 PM
trancedsailor's Avatar
Anyone know anything about this:
M and M Honda - Lower Arm Bar - Nengun Performance
It says it's for GD3. I would like this if it works. Already have a front lower arm bar (need a DIY for it btw)
Old Jun 22, 2009 | 11:48 PM
Slimjimx701x's Avatar
It's not all that hard. Fitfreak and I will not hold any responsibility about install.
You just need to lift the car and remove the wheels. Then remove the plastic guard on the lower control arms. After that remove the bolt that connect the lower control arm to the subframe, place the bar and place that same bolt back in at 70ft/pounds, and repeat on the other side. Then place everything back in, do a slow test drive to make sure it's save enough to drive to the alignment shop.
Old Jun 22, 2009 | 11:51 PM
wait so I need an alignment after the front lower bar install? I just got aligned 2 weeks ago....ugh...
Old Jun 22, 2009 | 11:55 PM
I needed, so I can only recomend the same. On mine it mess up my toes
EDIT: opps I didn't see the rear lower arm bar part, that diy is for the front. Sorry
Old Jun 23, 2009 | 05:47 PM
MNfit's Avatar
are you going to get one of these? Id like to see some pics of it on the car
Old Jun 23, 2009 | 06:54 PM
I'll only get it if someone confirms it will work.
Old Jun 23, 2009 | 07:25 PM
secondspassed's Avatar
Would this piece do the same thing as the Progress anti-sway bar?
Old Jun 23, 2009 | 08:04 PM
not sure, I already have the swaybar and front lower bar, so this would be awesome if it's something else entirely, but you might be right.
Old Jul 7, 2009 | 12:33 PM
FITGD3's Avatar
This is completely waste of $ you wont feel anything.
same as ASR, Beaks bars for Honda EG,EK DC etc.
Old Jul 7, 2009 | 01:16 PM
dewthedew's Avatar
this will do nothing compaired to the ultraracing rear lower bar...
Old Jul 7, 2009 | 01:26 PM
Will the Ultra rear lower bar interfere or replace the Progress swaybar?
Old Jul 7, 2009 | 01:31 PM
dewthedew's Avatar
nope redrumm runs both rsb and lower bar.
Old Jul 7, 2009 | 01:32 PM
Design wise, it shouldn't, but I would PM reddrumm before buying it
great now I have another suspension part that I want lol
Old Jul 7, 2009 | 01:37 PM
dewthedew's Avatar
Do it! i want a review from someone that isnt redrumm lol.
Old Jul 8, 2009 | 01:33 PM
doctordoom's Avatar
Supervillain
hm that's interesting. when i installed my lower arm bar, i called a vendor to ask, and he told me that i wouldn't need an alignment after putting in the lower arm bar.
are you absolutely certain that your toe was out from the installation and that an alignment is required after this install? or does anybody elsee know? it would make sense because i had an alignment done before this install and i didn't get one done after the install. then when i checked my tires later on down the road, they were wearing pretty unevenly and i got an alignment done again. now i don't know if it was a sh*tty alignment or because of this install...
Old Jul 8, 2009 | 08:38 PM
What happen on my, I'd installed in the middle of the night because I couldn't wait . But what I think what really happen is that I didn't have a bolt to spec
Old Jul 9, 2009 | 07:13 AM
FITGD3's Avatar
I would not recommend ULTRA RACING bars as well.. friend tested a few bars in the end nothing improved.
However, most of asian optionfan magazines say that ULTRA RACING bars are like Malaysian Carbing however Carbing VS Ultra racing bars are totally different story.
Ultra racing bars are made of steel which is extremely heavy, personally I stick with quality gear like SPOON, T1R, Js racing which they have done extensive R&D and race before they sell to the end users.
Have a look AJ RACING BEN's FIT......No rear lower bar, rear sway bar.
Driver mod is also important : )
BMW ALPINA
20
Sep 15, 2015 10:08 AM
sbualuba
Oct 14, 2009 11:29 PM
F'it_ImFromTx
Sep 1, 2008 10:31 PM
fit73
38
Jul 4, 2008 08:13 PM
pokems23
May 14, 2008 08:06 PM
