gram lights 57s
Old Jul 6, 2006 | 05:55 PM
sillypuddy's Avatar
Someone that Posts too much
gram lights 57s
I just picked up a set of used (but in very good condition) gram light 57s rims
just need to find hub rings
I know our stock size is 56mm and the gram lights are 63.3
what i need to know is do i need the stright or angle hub rings?
anybody help?
-joe
Old Jul 6, 2006 | 06:27 PM
phil_qc's Avatar
You don't need them, just be carefull when you torq your lugnuts...
Philippe
Old Jul 6, 2006 | 06:55 PM
sillypuddy's Avatar
i always run with them.. going to pick up a set tomorrow
-joe
Old Jul 6, 2006 | 08:24 PM
fazzster's Avatar
You will not need hub rings. The wheel is centered with the studs. Trust me, I run my Miata with Konig Heliums and no rings and it is smooth. Hub rings should only be used for example in most German cars because the wheel actually sits on the hub to center the wheel. German cars use bolts where as most Japanese use studs with lug nuts. Save your money.......here is a good link if you still have doubts....http://www.good-win-racing.com/mazda...ml?id=Nd3x9uHD
Just scroll down a bit at the link to read the Hubcentric ring section. Just make sure you use a torque wrench when you tighten your lugs. I usuallys use 80 ft/lbs.....
Old Jul 6, 2006 | 09:17 PM
LiL Wee FIT's Avatar
Wow another set of rims?!?!?
Old Jul 6, 2006 | 10:11 PM
07Fit00S2K's Avatar
FYI, we use rings for the Volks on the S2Ks.
Old Jul 6, 2006 | 10:15 PM
phil_qc's Avatar
The Fit is lug centric, not hub centric...
You don't need these rings...
Philippe
Old Jul 6, 2006 | 10:23 PM
skelly's Avatar
You need the hub rings. I've taken a Hunter Engineering course specific to Honda's they recommend using centering rings. Not only do they help center the wheel they also help support the weight of the vehicle rather than them being solely onthe studs. Do what you want, I'm only telling you what I've learnt at a Honda approved course.
If you don't know what Hunter Engineering is go here ---> http://www.hunter.com/
Old Jul 6, 2006 | 11:00 PM
sillypuddy's Avatar
don't know about you, but i don't want my lugs to be the only supporting points
and also without the rings on my 4 sets of rims, they all vibrate at highspeeds
with the rings, they don't at all
for $25 CAD, i am not going to cheap out on them
-joe
Old Jul 6, 2006 | 11:08 PM
phil_qc's Avatar
-joe
I understand that hubrings fill the gap between the hub and
the wheels... I don't have any vibration at any speed w/ my
Gram Lights 57S and I don't use rings... I just wanted to say
that it's a good idea to use these rings BUT it's not needed...
I'm verry carefull when I torq my lugs etc... Like you said: for
$25, go for it...
Philippe
Old Jul 6, 2006 | 11:10 PM
sillypuddy's Avatar
how fast do you go on the highway.. :-)
-joe
Old Jul 6, 2006 | 11:15 PM
phil_qc's Avatar
-joe
Faster than I should... most of the time is 120km/h but I like to
push the car limit so let say 150 160 170 but only when the road
is clear... don't want to kill someone or myself...
Philippe
Steven Hung
Oct 6, 2016 09:21 PM
rocketberger
Oct 16, 2012 10:09 PM
fitisno
Apr 23, 2011 09:51 PM
andyd
Jun 14, 2010 05:57 PM
kkim
May 11, 2006 03:10 PM
