Quote:
I noticed some people recommended to keep filling the tank after the first click. I've heard its best to stop at the first click due to the gas expanding or the vapors or some hooplah like that. What's everyones thoughts on that? I would like to be able to go longer without filling up, but don't want any negative effects. Plus the more weight in fuel you add the worse mpg you will get. Hmm...
I stop personally at two clicks. It clicks once, then I squeeze the pump trigger again til it clicks. The gas cap and tank are self venting so vapors and pressure shouldn't be an issue. All you are doing if you keep filling up after several clicks is filling up the filler neck, which is fairly long on the 09 fits.
__________________
Jet
Powered
Go
Cart
2009 Honda TFW GE8 Fit Sport-SRK
PRM Intake, Eibach Pro-Kit, HKS Hi-Power Axle-
Back, Mats, Auto-Shift Knob, Etc, Etc, Etc.....
My Automatic is better than your Manual!!!Supa-Dupa-Padle-Shifta!!!!!!!, Lol!!!!!!!
