View Single Post
  #81 (permalink)
Old 06-28-2009, 12:58 PM
justintime's Avatar
justintime justintime is offline
justintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to livejustintime relies on Rep Points to live
I went ahead and took some measurement with a digital temperature probe, with and without the insulation.
Here are my findings:
Test Procedure:
-Car parked in shade (attached house garage).
-Outside temperature approximately 83 F.
-Probe was located in center left vent. Temperature taken at vent output. Readings on this probe update every 5 secs.
-A/C in max fan speed mode, with the 'all upper vent' mode set on the dial (max air output on top vents, no air coming out of bottom vents).
-Recirculation mode ON; also set to OFF to test both conditions.
-Took readings after temperature had stabilized (i.e., when no change in temp after 20 secs the temp reading was taken and the test stopped).
-Tested with insulation, and without insulation. The last (small) portion of the run was not ever insulated.
-The material used was the highest grade 'rubber' plumbing insulation sold at Lowes. I also have the lighter grey foam material, seemingly lower grade/quality and certainly much cheaper, but did not test it.
WITHOUT INSULATION:
-Temp at vent, recirculation ON: 43.3 F
-Temp at vent, recirculation OFF: 60.9 F
WITH INSULATION:
-Temp at vent, recirc ON: 43.5 F
-Temp at vent, recirc OFF: 60.2 F
As you can see, there is not much difference. A variation of +- 0.5 degrees is probably within the error margin, so I consider these results ~ NO DIFFERENCE.
Note: I did not take 'time' readings, which I should have done. So, we have no way of knowing which condition cooled faster, but I can tell you I noticed the 'insulated' version to be cooling faster than the non-insulated. Sorry I don't have exact numbers in this regard.
Conclusion: No significant difference to final temperatures at vent, when adding insulation. Adding insulation however appears to cool the car faster.
Other tests to perform: test with car outside directly under sun on a hot day. Test with different foam material.
PICS showing material, test procedure, etc:
__________________
The $8 Grill Mesh Solution for the Fit, protect your A/C condenser etc.
Check my GE8 A/C insulation mod temp tests
