anyone make a urethane bushing kit
Old Jul 22, 2009 | 05:18 PM
revd34's Avatar
does anyone make a urethane bushing kit for our car? anyone have it on their car?
i called up energy suspension. they said that they won't be interested in making one.
Old Jul 25, 2009 | 05:34 PM
Evotech8's Avatar
Not sure about a complete kit, but Energy Suspension does carry a universal Front polyurethane sway bar bushing set that works on the Fit. I verified the dimensions while I had the stock ones off.
Its a easy, straight swap of the oem soft rubber bushing and bracket with these.
It does makes a noticeable handling difference since there is less flex with the polyurethane.
p/n# 9.5126 Hyperflex Performance Polyurethane Sway Bar Bushing, 22MM
Old Aug 12, 2009 | 01:16 PM
awptickes's Avatar
You sure the fit has a 21mm front sway? I was positive that it was a 22mm front bar.
http://automobiles.honda.com/fit/spe...oup=dimensions
Honda's site says 22mm.
Old Aug 12, 2009 | 03:10 PM
Evotech8's Avatar
Sorry, the correct p/n is: 9.5126
Energy Suspension 9.5126 Universal Sway Bar Bushings - 7/8 inch (22mm)
2009 Honda Fit - Specifications - Official Honda Web site
Old Aug 19, 2009 | 02:36 PM
awptickes's Avatar
I'm putting the sway bushings on tonight. I'll let everyone know how it goes.
Old Aug 19, 2009 | 05:18 PM
Evotech8's Avatar
On the install use a 12mm (or was it 14mm?) deep socket and one of those tilting-head type socket wrenches. Makes the job a whole lot easier reaching and loosening the bolts in tight spaces. On the driver side you will need to remove a plastic cover with 4 retainer clips.
Old Aug 19, 2009 | 05:36 PM
awptickes's Avatar
Yeah, it's 90F with 75% humidity.... I'm not doing anything outside. I'll put the bushings on when I do the mugen suspension install.
benmunger
May 16, 2009 02:30 PM
ChrisG
Feb 22, 2009 10:27 PM
ComposiMo
Feb 15, 2008 11:35 AM
tiF adnoH
May 26, 2006 11:03 PM
kkim
18
May 25, 2006 10:55 PM
