hardwire a radar detector
Old Jul 26, 2009 | 12:42 PM
Hamer460's Avatar
I tap mine to the map light, very easy and a very shorth run.
Old Jul 26, 2009 | 01:40 PM
Rubba Burna's Avatar
HID Addict
hmm, ill consider that as an option, but does that provide enough power for an RD? O.o
(RD = radar detecotr)
Old Jul 26, 2009 | 05:21 PM
Hamer460's Avatar
I have had it there for over a month now using a old escourt with no power problems.
Old Jul 26, 2009 | 05:40 PM
benmunger's Avatar
just so everyone knows. Hamer460 has a 2009.
I dont think there is a power with ignition wire, on the dome light, with the GD.
Old Jul 26, 2009 | 06:29 PM
HID Addict
i figured he had a 09, thought he meant the center dome light, but thanks for clearing that up
Old Jul 26, 2009 | 06:59 PM
Hamer460's Avatar
Sorry, yes I have a 2009
Old Aug 12, 2009 | 03:55 PM
Burbio's Avatar
How can I hardwire to the fuse box? I just bought a Cobra detector, and the power cord is the standard 12V DC to a small plug that connect to the unit. Can someone please explain how to wire it up?
Doug
Old Aug 12, 2009 | 04:28 PM
HID Addict
hmm, well for the V-1, it had a tap in wire included. i powered my V-1 by tapping into the wire that goes to the 12v adapter socket, tapped it right behind hte socket instead of under the steering wheel, coudnt be sure where the wire goes. if your ok with risking your cable, you can cut off the big adapter plug and open the wire, it should reveal a positive and a negetive/ground. tap the positive to the adapter and using a ring terminal (i think thats what its called) bolt that down using one of the existing bolts on the firewall. hope that helps. n its not my fault or fitfreak.net's fault if u mess it up, your choice to do it
P.S. i hope it wasnt one of those cheap cobras...
Old Aug 12, 2009 | 04:34 PM
Burbio's Avatar
Cool, thanks. I'll have to try that.
It wasn't cheap. Acutally it was the most expensive Cobra detector Best Buy had. It was like $180, it does 360 degree monitoring over 15 channels. I don't know how good it will be, but I wasn't gonna spend 400 on the V1, which i really wanted.
Old Aug 12, 2009 | 04:40 PM
benmunger's Avatar
Doug
If you unscrew and take apar tyour 12v plug you can get access to the 2 wires in there easily.
Old Aug 12, 2009 | 04:53 PM
HID Addict
lol i still dont trust my v-1, only b\c it hasnt come across a cop to put it to the test, but thats a good thing
Old Aug 12, 2009 | 05:30 PM
  #32
i thought maplights were constant voltage? (does not turn off even if your key is in the off position).
i cant remember if my GE maplights turned off with the ignition or not... i need to hardwire one for the wife.
Old Aug 12, 2009 | 09:25 PM
  #33
HID Addict
you dont have to do map light, my mehtod, it may be longer, but its still easy, the only trouble you'll have is getting your body underneath the dash lol
lilizm319
Apr 11, 2015 07:08 PM
GameOfWalkingBad
Mar 8, 2015 06:18 AM
2010Fit
Aug 1, 2010 10:57 AM
Burbio
Feb 18, 2010 07:14 PM
beans2_98
Apr 5, 2007 10:47 PM
