Cheap Ebay Armrest - Is it any good?
Old Jul 27, 2009 | 09:51 PM
TheRealBenzo's Avatar
what is wrong with the existing armrest?
Old Jul 27, 2009 | 09:56 PM
Committobefit08's Avatar
Please read the whole thread.
its actually a full arm center console with storage and actually slides up.
thus....
phillip's Avatar
it's uncomfortable, not adjustable, and doesn't have storage space
edit:beat me to the answer
Old Jul 27, 2009 | 10:00 PM
muuuhahahaha
Old Jul 27, 2009 | 10:10 PM
i like it so far...:dunno:
Old Jul 27, 2009 | 11:36 PM
secondspassed's Avatar
i'm glad you like the stock armrest, benzo. now, what exactly is it that you don't know?
Old Jul 27, 2009 | 11:48 PM
oh, idk...lol
Old Jul 28, 2009 | 01:04 AM
just sayin', a lot of people do mods here... if you go into every thread and ask "what's wrong with the way it is now?" you're not gonna make a lot of friends.
Old Jul 28, 2009 | 04:53 PM
gwh's Avatar
gwh
bought armrest from zeta fits good i did'nt even take out the origanal everything ok so far.
Old Jul 28, 2009 | 08:10 PM
Alright guys...I got my armrest. First off the armrest is pretty good quality. Easy to put together and is pretty sturdy. By the way its from Hong Kong not Cali.
It came with 6 screws even though there were only three holes to fasten to the existing console. I used the other three to add additional support. Three total in the bottom cup holder one in the side on the cup holder and two on the back tab. Of course its not going to hold your body weight but it will hold two arms easily and no worries about being unstable.
Now for the annoying part. I took off the existing armrest. There are two studs that stick out. See here on college hills honda instruction in step 2 of 5..
http://www.collegehillshonda.com/ins...09/armrest.pdf
Well they say you can unscrew it from the seat...well on mine you can't. They spot welded the nuts to the seat frame. So now I am not for sure what I am going to do with that existing hole. I might need to make some sort of cover for it....
I will keep you guys updated.
it also came with a piece of felt to lay in the inside of it. It is just laying in there in this picture. I used double sided tape to place it.
Summary for $50 you can't do better.
I will keep you all updated on the daily use. I'm interested to see how it holds up.
Old Jul 28, 2009 | 09:44 PM
Spiritborn's Avatar
^^^^^ Thanks for the updates and pics.
Old Jul 28, 2009 | 09:52 PM
  #32
ive caught on that this is a mod heavy forum.
im here to learn about my car, and gain general knowledge to what people have to say about it and what to look out for.
Old Jul 28, 2009 | 10:29 PM
  #33
Blazer Deli's Avatar
Thanks alot for the update! Looks like the existing holes in stock armrest are a problem. I wonder if you have room to install the stock armrest, but just keep it in the "up" position.
It really doesn't look bad at all for $50.
Old Jul 29, 2009 | 06:05 AM
  #34
Black3sr's Avatar
Is it any higher than original? I find my original is too low to use when driving. In my Dodge Caravan I am able to rest elbow albeit hand is not in best driving position. In the Fit I am finding I actually use a 10 and 2 position so the arm rest would have to be rather high.
Old Jul 29, 2009 | 06:11 AM
  #35
no I tried to reinstall the stock arm rest but it just wouldn't fit...not even in the up position. There is just not enough room for both.
I'm still not sure what I'm going to do with the existing holes. I might contact CollegeHillHonda and ask their advice since they think you can just take those bolts out and insert their plug.
Old Jul 29, 2009 | 06:12 AM
  #36
No actually its maybe about 1/2" lower than the stock.
Old Jul 29, 2009 | 09:31 AM
  #37
zetaproducts.net's Avatar
Former Vendor
Our armrest includes a plug to cover the stock seat-mounted armerst hole, just like the Honda OEM. Our armrest is sturdy enough to support the average driver. The one on eBay will fail over time. An armrest shold be able to hold you without fear of falling apart.
Old Jul 29, 2009 | 09:44 AM
  #38
Plug is worthless unless you can get the two studs that stick out off. They should be able to be unscrewed but mine you can't. See pics above.
They are spot welded the nuts to the seat frame. Care to enlighten?
Old Jul 29, 2009 | 10:08 AM
  #39
I can really argue the same thing about yours. Mine is sturdy enough to support the average driver right now too. Yes in the long run it might not hold up but who's to say yours will be any better. Based on what I've seen on yours you have a piece go into the rear cup holder and if you want you fasten in down with the one existing bolt. Just like what I've seen on the ebay armrest the one flaw I've seen is there is not alot of side support (meaning if you push on it from the side is it going to move. With the ebay one right now I used the extra screws included and fastened then on the inside cupholder to resolve this issue but with yours only sitting in the cup holder and with one bolt holding it down how is this resolved with yours?
Also what about the back area where your armrest comes over the back of the existing cupholder. You have a little ledge there to support the armrest and then continues down to your built in cupholder. What is to stop this area from scratching the existing console up especially if its only laying in there not securely fastened?
Don't get me wrong I am not trying to attach Zeta by any means but since I have the ebay armrest and have seen yours I don't see alot of differances from a consumer standpoint. Yes it might be slightly more secure but remember yours cost double. Truly the OEM one seems the most solid using heavy duty metal brackets but yet again your paying over triple the cost of the ebay armrest.
This again just reiterates you gotta pay to play I guess.
Old Jul 29, 2009 | 10:17 AM
  #40
Former Vendor
The 2 studs are not spot welded. Get a box wrench and apply some pressure. They do come off. I did this several times in our tests.
