Stainless Steel lines for GE8
Does anyone make the ss lines for a ge yet?
The only kits I've seen for the fit only include 4 lines, where the GE8 has six rubber brake lines.
EDIT: On second inspection, it only has 4-- false alarm.
~Robert
TEFLON BRAKE LINE MATCHING LIST (ENGLISH).
Yeah, for $368... No thanks. Besides, they're really ugly.
I am currently working with Goodridge to help them make a set of their lines for the GE8 Fit and add them to their application guide and catalog in the near future. I sent them a full set of the Honda OEM brake lines and they're prototyping some stainless steel Goodridge lines at the moment.
There are some small issues with duplicating the OEM metal brackets at the ends of the lines, but they should be able to figure out a solution. If not, some very minor modification may have to be made to the car (a drilled hole) so that a tab from one the brackets will slot in (it prevents rotation of the end of the line and bracket).
Stay tuned! I'm waiting to hear more from Goodridge in the next week or so.
Cheers,
Baz
Cheers,
Baz
Cheers,
Baz
Cheers,
Baz
I was out of town (for a month) when the prototype lines arrived
, so I'm just now getting set for a day in the shop to test fit them. They look fantastically well put together, I'll say that much. I should have an update in a few weeks. Need to give them (Goodridge) a call and update them on where I am in the process.
Cheers,
Baz
, so I'm just now getting set for a day in the shop to test fit them. They look fantastically well put together, I'll say that much. I should have an update in a few weeks. Need to give them (Goodridge) a call and update them on where I am in the process.Cheers,
Baz
Cheers,
Baz
Baz
Bringing this one back from the dead. I recently purchased a Goodridge G-Stop SS brakeline kit (part #20114) from the tirerack and the kit came with the wrong brackets in the package. After calling Goodridge, I learned that they recently changed the bracket design based on similar calls from other GE Fit owners. Just thought I'd let you know that if you get stuck trying to figure out how the front brackets are supposed to fit, you'll need to give them at call at 310-533-1924 and have them send you an updated set.
samcl9
Nov 24, 2015 07:52 PM
BlueBoogers
May 15, 2012 05:47 AM
KeithDigital
Jan 4, 2012 02:38 PM
awptickes
Aug 23, 2009 12:28 AM
