Wheel Spacers?
Old Aug 6, 2009 | 01:41 PM
KoolMikeSki's Avatar
Wheel Spacers?
What size wheel spacers can I run with out have to get extended lugs?
I was thinking 8mm to 10mm?
Old Aug 6, 2009 | 03:26 PM
GD3_Wagoon's Avatar
on the stock wheel studs, i wouldn't risk anything beyond a 5mm spacer just for safety reasons. as easy as they are to cross thread they're relatively weak and putting more stress on the ends of them can't be a good idea; i've always been told that you want at least 7 turns on the wheel nut when tightening your wheels down.
Old Aug 6, 2009 | 04:27 PM
grtpumpkin's Avatar
Even 6mm is pushing it. It is best to put on the longer studs with spacers for the sake of safety. I am running 15mm H&R DRS in the back with extended studs, and they would not have worked AT ALL with the stock studs. Car looks 1000 times better with the rear tires pushed out from under the car BTW....
Last edited by grtpumpkin; Aug 6, 2009 at 04:31 PM. Reason: couldn't remember spacer size LOL
Old Aug 6, 2009 | 04:37 PM
get the kic's 15mm that comes with its own studs build-in.
you dont need to dissassemble the drums or anything. i use it on my G35C.
Old Aug 6, 2009 | 05:03 PM
GD3_Wagoon's Avatar
pics?? are you still on the sport wheels? i've always been interested in this but never had the balls to try it myself.
Old Aug 7, 2009 | 02:25 AM
Fit4Trav's Avatar
Putting the 15mm spacer would make the offset +40 charlie so it would help a ton. (if he's using the stock wheels)
As said above 5mm is the largest that I would use with out running the extended studs, but some spacers (as posted above) come with studs already built in.
Old Aug 7, 2009 | 04:06 PM
grtpumpkin's Avatar
If you run a search for a thread i started called "It works!...I knew it would" you'll see the whole story from end to end with pics. The car looks much better w/spacers in the back IMHO. The rear studs are actually pretty easy to get out (of course i have a 12 ton shop press go figure) but the fronts are such a PITA that Ray figured out a way to remove them without removing the hub. Unfortunately it involves using a right angle grinder on the spindle, which was a little too adventuresome for me....
Shot with KODAK C360 ZOOM DIGITAL CAMERA at 2009-03-30
Shot with KODAK C360 ZOOM DIGITAL CAMERA at 2009-03-17
Old Aug 8, 2009 | 05:45 AM
feared's Avatar
would spacers in the rear be beneficial to the car's handling in anyway?
Old Aug 8, 2009 | 09:10 PM
grtpumpkin's Avatar
Ever so slightly wider track in the rear can't hurt! I don't really feel the need for a RSB as the car already has more grip than i have nerve.
Old Aug 8, 2009 | 11:26 PM
Daemione's Avatar
Yes and no . . .
A wider track lowers the center of gravity. A lower COG reduces weight transfer. Less weight transfer increases grip (to a point). But on a car that already understeers, a grip increase only on the rear end isn't going to be of much practical use. In fact, without other upgrades or adjustments it'll just exacerbate the car's less desirable handling traits.
That said, it also depends on how you define "handling".
Old Aug 9, 2009 | 12:04 AM
feared's Avatar
Originally Posted by Daemione
Yes and no . . .
that answered my question, thanks
Old Aug 9, 2009 | 09:15 PM
That's right, pushing out the rear wheels has the similar effect as increasing torsion rate on the front swaybar. If you are going to push out the rear, push out the front as well.
If you want more over steer bias you want to pushout the front and leave the rear as is.
Another thing to note about the Kics is that you don't need any special tools. Just place on the hub, tighten down the special low profile lugs (kit comes with adapter), place your stock wheel, tighten down wheels using your stock lugs.
Razzer
Jul 19, 2013 05:26 PM
BlueBoogers
May 13, 2012 08:57 PM
MIAMIFIT
Apr 6, 2010 01:06 AM
heymikesays
Oct 25, 2006 09:50 AM
