Yes, pretty much sanding is the only way if you want the emblem to stick right. Not sure of any model Honda out there will work perfect for it or not. I doubt it otherwise Jdmland/icb would of had them.
If you decide to do it without a dremel get very coarse sand paper. I used 3M 60 grit automotive sandpaper. (Green) and it took a little while. If you have the money, get a dremel, if not get some 60 grit or below and some elbow grease.
__________________
'07 Fit Sport, NBP, 5AT
