Help with cat delete
Old Aug 15, 2009 | 11:07 PM
Nighthawk_GD3's Avatar
Well i installed my cat delete with the supplied CEL fix but of course it still through the CEL. Any fixes for this? or do i just have to deal with it?
Old Aug 16, 2009 | 01:09 AM
im the fit's Avatar
Just add another cel fix!!!!!!!!!!
Old Aug 16, 2009 | 01:10 AM
im the fit's Avatar
its going to work 100%
Old Aug 16, 2009 | 01:36 AM
Hmm. Not sure the wires on the sensor are long enough for that.
Old Aug 16, 2009 | 02:58 PM
koolkevin1107's Avatar
Did u reset ur ecu after u installed the cat-delete? U have to disconnect the battery for 10 minutes to remove the code and let the car "re-learn" all the sensors. Just take of the negative terminal. That should fix ur CEL. If u have the oem radio, make sure to have ur radio code ready cuz u will have to re-input the code when u disconnect the battery.
Old Aug 16, 2009 | 03:08 PM
Well the CEL didnt come on until about 5 days after i installed it
Old Dec 17, 2009 | 02:28 PM
5speedwonder's Avatar
I have the same problem after my install, if its anything like my other cars its just a "hey stupid" light and doesn't have any negative side effects. Or I could be wrong and the fit may be different?
Old Dec 17, 2009 | 06:26 PM
rvall004's Avatar
the light comes up because the bung for the sensor that is on the cat delete is not long enough to not read the hot gases coming from the engine..just get a cel fix extension and that should take care of the problem..
Old Dec 22, 2009 | 12:01 PM
does the cel actually cause any issues (a/f irregularities, limp mode, etc) or is it just a dummy light saying its reading that the cat isnt doing its job? i havent noticed any problems since the light came on.
edit: i am gonna fix it, its just a tad bit cold out hahaha...
Old Dec 26, 2009 | 11:57 PM
modfit669's Avatar
did you notice losing any torque when you deleted your cat???
Old Dec 27, 2009 | 12:03 AM
I didnt notice in loss in torque. If anything it should have helped. But for now i put the stock cat back in place. I am going to go with the resonated delete from Megan sometime in the future to quiet things down a tad. And i may order an o2 extension from ClubRSX and add a second CEL fix just to make sure i dont get the dang light.
Old Dec 27, 2009 | 12:07 AM
modfit669's Avatar
yeah i have that stupid light to but i just liv with it. iv been trying to get more torque threw first second and third and my freind who owns a hot rod shop said i shud put my cat back on because of backpressure and that shud give me more torque. but idk thats why i was asking
Old Dec 27, 2009 | 12:14 AM
Only real way to find out is to slap it on the dyno with and w/o the cat. Sometimes the ol' butt dyno can play tricks on your mind.
Old Dec 27, 2009 | 12:20 AM
modfit669's Avatar
hahah ya i no. are alot of people running with out the cat?? there isnt much talk on here bout them...
Alex Smith
Jan 26, 2018 08:20 AM
Orcshine101
Nov 10, 2016 10:04 AM
fisheyefool
Aug 14, 2014 09:30 PM
redfit_pr
Jun 16, 2009 02:50 AM
