Kraftwerks SC and what else ?!
Old Aug 17, 2009 | 12:07 PM
vinnimac's Avatar
I am strongly looking at going with the Kraftwerks SC kit, but want to maximize my output as long as I going for it. I will be driving on public roads so I must retain the cat., but was wondering what else I could do with the exhaust that would be most beneficial. Do you see more with a cat-back vs axle-back, or is about the same as you are still dealing with the cat? Does an aftermarket header help or just a waste of money?
I am really hoping someone from Kraftwerks will pick this up and respond, but if you have had a really good, or bad, experience with the subject, feel free to chime in. Thanks all
Old Aug 17, 2009 | 12:26 PM
dewthedew's Avatar
I would suggest going with a megan header and megan cat back. For other power adders Id read more into the KWSC threads.
Old Aug 30, 2009 | 07:10 PM
Koi's Avatar
Koi
OSR said the Megan 4-1 Header gave good gains while the tri-y WeaponR street header actually killed some power. So, any quality 4-1 header will probably bump up output a tiny bit w/o leaning it out much.
Old Aug 31, 2009 | 03:56 AM
revd34's Avatar
i have j's racing header and t1r b-pipe and j's racing axel back. i had these on when i put the KWSC on before so i can't tell you the difference but im pretty sure it made a difference.
as far as bad experiences i was so lucky to have something go under my car and destroy the rotrex oil filter and seize up the rotrex. i'm the only one that had this happen to. you shouldn't worry to much about it or you can just get the beatrush underpanel
here is a link:
https://www.fitfreak.net/forums/fit-...my-rotrex.html
btw if you couldn't tell i'm selling my kit
Old Aug 31, 2009 | 05:10 AM
Koi's Avatar
Koi
You mean unlucky?
Old Aug 31, 2009 | 10:35 PM
revd34's Avatar
Originally Posted by Koi
You mean unlucky?
i was being sarcastic
Old Aug 31, 2009 | 10:52 PM
Koi's Avatar
Koi
Ah. Carry on then
MISTERHONDA
Feb 20, 2016 10:18 AM
Cordizzle4life
May 27, 2014 11:51 PM
Fit of RAGE
38
Jan 9, 2013 11:01 AM
gthumb23
Mar 29, 2007 06:10 PM
