what is the max boost for stock L15A
Old Aug 26, 2009 | 11:34 AM
clanbuster's Avatar
Currently my boost upto 0.5 bar (7.2 PSI)
for my stock L15A using TD04
what is the max boost i can go for stock engine?
Old Aug 26, 2009 | 12:46 PM
keepitpg's Avatar
i love college
the pistons and rods can take about 19 psi, but the sleeves can only handle around 10 psi safely.
Old Aug 27, 2009 | 01:04 PM
clanbuster's Avatar
thank you for your infomation.
so if i want to boost 1.0bar ( 14psi) , i still have to change sleeves and it mean have to take out the whole engine just to change the sleeves?
if so, i may consider change pistons and rods since already taken out. Does cosworth have L15A con rod and pistons , gaskets? anything i still need to change?
Old Aug 27, 2009 | 01:11 PM
keepitpg's Avatar
i love college
if you want the engine to last with stock internals stay 10psi or below, otherwise youd probably have to change everything out.
Old Aug 27, 2009 | 02:11 PM
kylerwho's Avatar
spoon fed
stunk2 ran their fit at 21psi and blew the motor. im pretty sure they run it at a constant 15psi during the track time and it seems to hold it together.
jdmchris is at 12psi and his fit i staying together. a few other members on here are running the turbo setup at about 9psi and it seems rather reliable.
look for gd3kamiwanaB's motor build thread. he did a full motor bild and he is running 18-22psi daily and it seems to be holding up rather well.
Old Aug 27, 2009 | 07:11 PM
ap_fit's Avatar
yes, from everything I'm hearing the high boost kwsc is running at 12 psi...and I think it's safe the say the jacksons aren't going to release something that will blow ur motor...
Old Aug 27, 2009 | 10:16 PM
kylerwho's Avatar
spoon fed
boost will blow your motor sooner than na but you just have to take safety precautions to make sure your motor will last. the jacksons are building a true bolt on supercharger kit that is close to oem so they keep their good reputation.
tuning is the real key to prevent from destroying your motor...
Old Sep 5, 2009 | 10:27 PM
underdog's Avatar
boost is a bad way to look at things. It mostly comes down to horsepower and cylinder pressures. a small turbo will build crazy cylinder pressure at low rpm's with high boost which can cause more problems than boost up top. also too much timing especially at lower rpms with boost can be more dangerous than higher boost with correct timing(too low is bad as well, raises egt's)
example a large t3/t4 could blow the engine by exceeding the horsepower capability of the componets with boost as low as 7psi
and a t25 could possibly survive at 15psi as long as boost doesnt come in to violently down low.
other things that can cause problems is excessive backpressure from either the exhaust system or a improperly sized turbo and most importantly. TUNING!
Old Sep 6, 2009 | 04:35 AM
kylerwho's Avatar
spoon fed
true boost is a bad gauge for the saying when the motor will explode but i had in mind the standard garrett t28 (i think) which comes with the t1r kit in mind when i posted.
Old Sep 6, 2009 | 11:01 AM
underdog's Avatar
is it that big? I always thought they used a t25? guess nobody ever confirmed what it was?
Old Sep 8, 2009 | 10:25 PM
gd3kamiwanaB's Avatar
Luvs Dah b00st!
t1r is same turbo as hks t25 journal bearing. t28 is the turbo i need to make 300, the t25 is only good for 220. i know this cuz my hks turbo is ALL THE WAY turned up and we could only yeld power of 220, on a side note my stock rods let go on a detonation at 10lbs, looked like taffy
Size:  81.9 KBName:  100_8147.jpg
now look what the correct rod for the job looks like,
Old Sep 8, 2009 | 10:59 PM
dewthedew's Avatar
hi boost kwsc is 12psi? i didnt know that
Old Sep 9, 2009 | 12:01 AM
ap_fit's Avatar
detonation can be prevented with a proper tune
Old Sep 9, 2009 | 12:11 AM
JDMchris.com's Avatar
I run THIS
its not quite 12.... Im like 11.6 but yes the tune is what makes or breaks it for the most part.
Old Sep 23, 2009 | 12:24 PM
TheFitman's Avatar
hks = fail fail fail fail
(or the installer/tuner is a failure)
either way somebody/everybody screwed up BIG TIME
kwsc for the win
Old Sep 23, 2009 | 03:09 PM
kylerwho's Avatar
spoon fed
nobody screwed up with that build. josh just happened to find the melting point for the fit. than he drank a beer listened to daft punk's harder, better, faster, stronger and decided to rebuild.
Old Sep 23, 2009 | 03:24 PM
Luvs Dah b00st!
kwsc for the win
delete......
Last edited by gimme; Sep 23, 2009 at 04:30 PM. Reason: insulting members is not so fun?
Old Oct 2, 2009 | 02:50 PM
explosivpotato's Avatar
I'd be worried about running more than 200WHP on a stock motor. It won't be the sleeves that let go, as Josh has found out for us. You'll banana a rod first. Of course it's all in the tune, thats why I'm running the T1R kit with different management - the Emanage Ultimate can't control SHIT on our cars.
Old Nov 26, 2010 | 05:31 AM
Lyon[Nightroad]'s Avatar
Muahhahaa wouldnt have hapened on a ge8 with them stock forged rods Silly question but did lower compression pistons exist for you gd folks back then?
Bump from the grave for no good reason.
Old Nov 26, 2010 | 09:40 AM
kylerwho's Avatar
spoon fed
there are no real lower compression pistons. the forged units now made are running the same compression as stock i believe.
no one is running higher boost on the ge to really test their melting point but i wouldnt be suprised to see you get around 240hp before self destruction happens.
