skunk 2 springs with 4omm off 17in rub?
Old Aug 27, 2009 | 12:37 AM
phatmonster's Avatar
im gonna run skunk 2 springs with 4omm off 17in konig bumps? will i get any rubbing issues? 205/40/17 or 195 /40 17? i got the spring and rims but havent bought the tires yet.Any one running skunk2 springs with 17's?
Old Aug 27, 2009 | 01:21 AM
any suggestions?
Old Aug 29, 2009 | 04:11 PM
GTornado's Avatar
I am running Tein s.tech springs (40/35mm), 7x17 +42 rims on 205/40/17. I had slight rubbing in the back when turning real quick around the corners with one passenger (in the back). As a result, I had to pull fenders in the back.
Maybe you should try 195 tires but due to the small tire wall the ride will be quite hard, I guess.
Old Sep 26, 2009 | 01:01 AM
Front rubbing
i just put 205 40 17 40 offset
it sounds like im getting rubb in the front when cornering or hard bump. Easy fix?
using skunk2 springs with stock struts
purplekush
Feb 3, 2013 12:29 AM
j1nNju1c3
Aug 13, 2010 10:04 PM
phatmonster
Aug 24, 2009 07:55 AM
Luichenwai
Jun 29, 2007 12:37 PM
abcsr2ez4me
Apr 30, 2007 07:19 PM
