Brake kits for 15" wheels?
Old Sep 2, 2009 | 12:32 PM
DrKelso's Avatar
Does anyone know of any brake kits that will fit inside of a 15" wheel? Most of the complete brake kits that I've found require at least a 17" wheel. Is there such thing as a medium brake kit?
My only other option would be to replace my pads/rotors, but I'd really like to replace the caliper, as well, if it's possible.
Post up if you know something. I'm sure I'm not the only one looking for one
Old Sep 2, 2009 | 02:53 PM
GTornado's Avatar
Try to look for the D2 Racing 6 pot brake kit. It is suitable for 15" wheels with slotted rotors, stainless brake lines and new calipers.
Old Sep 2, 2009 | 11:17 PM
CamFit's Avatar
wow crazy price for break's
Old Sep 2, 2009 | 11:28 PM
radareclipse's Avatar
Call Brian at Fastbrakes.com in Arizona.
602-323-2110
Old Sep 2, 2009 | 11:51 PM
dewthedew's Avatar
Interested in this.
Old Sep 7, 2009 | 12:06 PM
FITGD3's Avatar
Project Mu brake kit, Endless brake kit are available for HONDA FIT GD3 work under 15inch.
Old Sep 7, 2009 | 12:14 PM
awptickes's Avatar
ITR calipers and rotors.
RSX-S calipers and rotors.
Old Sep 27, 2009 | 10:34 PM
Jodele's Avatar
Old Sep 27, 2009 | 11:02 PM
awptickes's Avatar
Big brake kits are like always having an import model in your passenger seat. Sure, it makes the car look really good, but in the end it hurts performance.
That being said: if you have a true need for a BBK, go for it, but otherwise you just need pads. Start toying with pad compound before swapping around parts.
Old Sep 28, 2009 | 12:05 AM
redrumm's Avatar
what rims are you running?
Old Sep 28, 2009 | 01:01 AM
El Chupacabura's Avatar
Won't the T1R bake kit fit in the stock wheels?
Old Sep 28, 2009 | 05:08 AM
Fit4Trav's Avatar
JBT mini Big brake kit
I'll have to scrounge up some more info. But I know a few Scion guys that run this set-up
Old Sep 28, 2009 | 05:33 AM
kelsodeez's Avatar
UNBANABLE
my spoons fit my volks with no spacers.
and those are 15x7
Old Sep 28, 2009 | 07:28 AM
Jodele's Avatar
Very good analogy…just like girls, if you aren’t getting any performance increase, you’ve chosen the wrong one! There are pretty girls, smart girls and sex crazed girls, if you don’t get it all…you need a different one. Super models are great to look at in a magazine, but I like the ones that perform between the sheets the most – if you know what I meanJ Try a Playboy centerfold…they are just a beautiful and not just easy on the eyes – they perform well too!
Yes…I agree…a lot of big brakes out there are just eye candy (all show and no go), so choose carefully.
In the Type-R brakes link, there are lots of variations listed; from cheap to high performance…all that fit in a 15-inch wheel.
Old Sep 28, 2009 | 10:43 AM
awptickes's Avatar
Guys, remember that bbk pads cost a small fortune. If you just pick up a set of decent pads (I prefer Hawk HPS) they'll be pretty cheap. I've got a brand new set I'll sell for $60.
Old Oct 9, 2009 | 08:12 AM
Jodele's Avatar
If they are so great, why are you selling them off?
For about twice that, you could have something really great if you install the Integra Type-R front discs. Check out this thread https://www.fitfreak.net/forums/fit-...tallation.html
Old Oct 9, 2009 | 11:54 AM
awptickes's Avatar
I have an extra pair. When I ordered them I bought two from different dealers because I needed to make sure I had them for autocross on saturday.
Now I've got an extra set of pads. I think I'll just keep 'em.
Old Nov 18, 2009 | 10:05 PM
MarcoM's Avatar
What Project mu's won't fit
Project µ’s will not fit 15” Weds SA-70’s.
Anyone sure of what 15” wheels they will fit?
When the calipers are actually mounted, it's even worse: holes don't even come close to lineing up. I am supremely bummed that I'll be losing these wheels, but I refuse to go up to a 16". Like I said, anybody absolutely sure which 15" wheel will fit.
Old Nov 19, 2009 | 04:44 PM
Jodele's Avatar
OK…here is what you need to do. Get a carpenter’s square (it looks like a big “L”). They are usually about 24” long on one leg and about 18” long on the other. Mount the brakes on the car and lay the long leg of the square over the flat face of the hub. This will take some doing because of the raised center for the centric mounting of the wheel. Putting a machined spacer would work here too. Rotate the hub with the square to find the furthest distance. Measure that distance to the center of the hub and add an eighth of an inch for clearance. Then you go shopping.
Word of advice…find the lightest wheels you can…lighter means less material – thinner sections = larger diameter. I’d start with Enkei Enkei Wheels : 2009 Race & Tuning Series
Old Nov 19, 2009 | 09:14 PM
Texas Coyote's Avatar
If you are to get some Enkei RPF1 wheels and some lighter tires you might be surprised to find that you don't need bigger brakes...... I did it and think that it surpassed the KWSC, I also have, as an improvement.
