T1R Radiator Hose...
Old Sep 13, 2009 | 10:27 PM
Mr08FiT's Avatar
I just finished doing mine today so I thought I would try and wright up a how to...
These are the tools I used to complete the install
First I started by removing the air box
Second I put the front driverside up on a jackstand, and opened the drain plug on the radiator. While that was draining I removed the plastic undertray to access the lower hose clamp.
I found it easier to un-clip the wire harness that ran just above the upper hose rather than work around it. The clips are super easy just be gentle and they'll slide right off giving you about 2"-3" of slack.
Remove the hose clamps and then remove the hoses, it may take some elbow greece and persuation.
Instal new hoses with original hose clamps, I'm sure you could use something newer I didn't have any
Install air box, fill with coolant. I ran the car for two cycles: fans on then off. I also threw a check engine light so I had to disconect the battery for about 20 minutes, reconnected the battery everything was fine.
Old Sep 13, 2009 | 10:41 PM
thefit09's Avatar
What's the benefit to these?
Old Sep 13, 2009 | 10:52 PM
Mr08FiT's Avatar
They look pretty, lol... maybe they have a higher temp rating than stock?
Old Sep 13, 2009 | 11:09 PM
dewthedew's Avatar
Nice, I almost bought a set of these but they dont come in black.
Old Sep 14, 2009 | 01:13 AM
im the fit's Avatar
To also keep better pressure!
Old Sep 14, 2009 | 10:20 AM
Mr08FiT's Avatar
^ word.....
Old Sep 14, 2009 | 10:29 AM
kylerwho's Avatar
spoon fed
i noticed my temperatures on the scangauge went down by like 3 while freeway driving.
Old Sep 14, 2009 | 10:33 AM
TurboManGT's Avatar
Rep for you thanx for the pics and how to
Old Sep 14, 2009 | 11:29 PM
DrKelso's Avatar
Nice writeup, Scott! +rep to you
This is definitely on my "short-term goal" list for mods. I want to do this before winter hits for sure.
Old Nov 8, 2009 | 04:21 AM
socalsmirff's Avatar
these hoses are great. you will have a way lower chance of ever having a busted radiator hose. worth the cost in the long term life of the car, for those that have ever had a busted radiator hose... it sucks.
Old Jan 8, 2012 | 08:26 PM
Lance's Avatar
Just Installed T1R Earthing and Grounding kit
I am happy knowing the first coolant flush on my 5 year old FIT was combined with the T1R hose upgrade, and will be good for a long time. Also upgraded the grounding wires with the T1R earthing kit. The overall feel is good. But the car feels good already and you cant put a price on piece of mind. I think I could feel the car drive faster but that is because I was using my right foot more.
gynosis
109
Aug 10, 2014 07:55 PM
qbmurderer13
Dec 11, 2010 08:10 AM
qbmurderer13
Mar 14, 2009 01:25 PM
qbmurderer13
Jan 26, 2009 12:20 AM
Fit4Trav
Car Shows, Events, and Racing
20
Dec 23, 2008 09:07 PM
