Longer wheel studs...
Old Sep 21, 2009 | 08:42 AM
Mr08FiT's Avatar
I was just wondering if anyone has these... I tried fitting spacers out back and the lug only went 2-3threads deep(no bueno). Thank you for your input...
Old Sep 21, 2009 | 01:09 PM
GD3_Wagoon's Avatar
arp extended lug studs should do the trick :thumbsup:
arp extended lug studs - Google Product Search
a couple of the socal Fit owners are running these wheel studs. Note is for sure.
Old Sep 21, 2009 | 03:29 PM
kylerwho's Avatar
spoon fed
kelsodeez is running the longer wheel studs
Old Sep 25, 2009 | 07:25 PM
grtpumpkin's Avatar
I also installed longer studs (when I went with 10mm spacers in the back) They aren't that hard to do, if you have a shop press as I do Tee-Hee. If not than I believe you can knock them out with a hammer. The new ones are drawn in by threading a lug nut onto the new stud and tightening it down until it has been pulled snug into the hub. The only spacers that will fit on stock studs are three to five MMs which is hardly worth the trouble LOL
GAFIT
Aug 13, 2017 08:19 PM
BlueBoogers
May 13, 2012 08:57 PM
xFERNx
Oct 19, 2010 06:20 PM
KoolMikeSki
Aug 9, 2009 09:15 PM
