B Pipe Sound Question
Old Oct 5, 2009 | 11:52 PM
DarkFit's Avatar
How much more sound does an aftermarket B Pipe (such as the Aspec) produce compared to the stock B Pipe?
I have an Aspec axle back right now and I am debating whether or not its worth buying an aftermarket B pipe. I just want my exhaust a little louder than what it is right now.
So would it be significantly louder or not even noticeable, compared to the stock b pipe?
Thanks.
Old Oct 6, 2009 | 10:42 AM
Mr08FiT's Avatar
Yo yo, yes the B-pipe will help make it a little deeper. You should just run what I was: aspec header, keep stock cat, aspec b-pipe, aspec axle back. That right there is a great sounding exhaust set-up. IMO
If you do just the B-pipe it will sound deeper
Old Oct 6, 2009 | 03:25 PM
kylerwho's Avatar
spoon fed
its all depends on the size and if the b pipe has a resinator.
it mostly makes the exhaust deeper in tone.
get j's cause it is a straight through design and will really make a nice tone.
Old Oct 6, 2009 | 07:28 PM
DarkFit's Avatar
Thanks for the replies guys.
I think I am just going to go with the Aspec B Pipe as the price is much better than the J's.
Old Oct 7, 2009 | 02:27 AM
doctordoom's Avatar
Supervillain
the j's b-pipe is not resonated, so it will not give a nice resonated sound. it would be more of a raw, popping, droning, and farting noise. i'd suggest a resonated pipe unless you want your car to be an attention whore haha, or you're turning your car into a track monster that will be worthy of the noise it generates.
Old Oct 7, 2009 | 12:05 PM
GD3_Wagoon's Avatar
the aspec b-pipe hangs low (just like the megan b-pipe). if you're lowered, there is a possibility that the resonator will get caught in some driveways depending on how well you're able to angle in. i had to sell my megan b-pipe because i was slammed and couldn't get into my apartment garage without coming in practically parallel to the driveway.
for a cheap fix you can buy worm clamps at any auto-parts store and pull the b-pipe closer to the car VIA the exhaust hangars. you can raise it up a good inch to an inch and a half; however, it will still hang lower than the OEM b-pipe.
Old Oct 7, 2009 | 01:49 PM
BoriJDMGD3's Avatar
Ihh IS Jaaaarome!
if you want to be alittle louder buy my T1R test pipe...
Old Oct 7, 2009 | 10:28 PM
DarkFit's Avatar
@Bori
I think I am going to keep my cat lol.
@GD3Wagoon
My car is now lowered at all, still on stock springs.
But I read that the Aspec is the highest sitting aftermarket B pipe, am I right?
FittedOnEm
39
Jan 15, 2017 01:50 AM
SikxChoi
Aug 11, 2011 11:29 PM
dustin_said_hi
16
Apr 22, 2010 02:50 AM
sy11580
18
Oct 9, 2008 12:59 AM
ashsblrsxtrg2006
Dec 18, 2006 08:54 PM
