For those using T1R Dampers / Shocks
Old Oct 14, 2009 | 04:25 AM
iheartmyGD3's Avatar
I'm currently running T1R dampers with Eibach Sportlines right now (on 15's) and I'm rubbing like crazy.
For those of you with T1R dampers what kind of lowering springs do you guys have?
How's the ride quality? Any rubbing?
I need suggestions on what springs to switch to.
Thanks!
Old Oct 14, 2009 | 09:03 AM
FITGD3's Avatar
maybe your springs too soft?whats the spring rate?
you should consider more stiffer spring rate
Old Oct 14, 2009 | 10:14 AM
Fitting's Avatar
Specs on your wheels/tires. Depend on sizing might explain why you rubs.
Old Oct 14, 2009 | 11:26 AM
GD3_Wagoon's Avatar
^^agree
if you ran a tire with a smaller sidewall or width you could avoid any rubbing.
have you rolled your fenders yet? my wheels are 16x7 +38 on 205/45/16 tires and i rub a little bit on bumps/drop-offs -- if i roll my fenders i could avoid any rubbing altogether
Old Oct 14, 2009 | 12:40 PM
doctordoom's Avatar
Supervillain
^ yup what they said. your wheels and tires are the culprit.
Old Oct 14, 2009 | 12:48 PM
willitfit's Avatar
what type of rubbing is it? rubbing when you turn, brake, accelerate, have people in the car, or just driving straight.
sportlines arnt soft, they are pretty stiff like skunk2's and you have t1r shocks.
Old Oct 14, 2009 | 01:21 PM
thanks for the speedy replies everyone.
my slips are 15x6.5 4x100 +40 mounted on 195/55-15 tires. i dont really see any issue with this setup (conventional wisdom says i shouldn't, no?). it's pretty puzzling because when i was on stock shocks with the eibach sportlines i NEVER rubbed in ANY instance even with a full car.
i'm guessing my t1r dampers either lowered the car even more.. or is just completely softer than our stock shocks.
right now i'm completely rubbing when I have 4 people in the car,
when it's just me in the cockpit it rubs on bumps/drops and sharp turns.
(note that this is at the softest AND stiffest setting)
also when i hit bumps it feels like i'm running ebay coilovers and its pretty brutal as i can feel the impact throughout the whole car.
Old Oct 14, 2009 | 09:51 PM
eldaino's Avatar
weird. the settings on them wont determine the drop, but they should affect ride quality. do they feel like ebay coilovers even at the softest setting? they were supposed to feel comfier at that setting, not worse.
the ebach springs are not super soft or anything...and our cars techincally need better dampers with the stock springs. a could shock should match up to even the stock springs and improve handling....suprised to hear that these dont?
that offset is pushing it a little...you may want to try running a 50 series tire...but even then, with your set up i would expect a little rubbing, but not to the degree you are saying. the eibachs for our car lower a bit more than advertised though...but still.
Old Dec 8, 2009 | 01:06 AM
andyd's Avatar
the dampers do allow the springs to compress more. I noticed that when i added them with my teins. it is weird.
Old Jan 12, 2010 | 10:13 PM
theFITMASTER's Avatar
how is puzzling that the stock rim width is 5.5 inches - a full inch narrower
and that stock offset is +55 ....thats a whopping 15mm (half an inch)
thats right ladies and gentlemen.....you r roughly half an inch closer to the fender than stock!!!!!!!!!!!!!!
quite puzzling indeed!!!!!!!!!
did u know those numbers +40 and +55 r not just numbers for math geeks but actually mean something in the real world?
please stay far far away from what u call "conventional wisdom"
there is a reason why they call it "conventional wisdom" and not just "wisdom"
sandblasted
28
Aug 29, 2012 07:38 PM
GE8_typeR
Jul 31, 2012 05:48 PM
j1nNju1c3
Aug 13, 2010 10:04 PM
xonexlifex
Dec 20, 2009 04:30 PM
413FIT
17
Sep 24, 2009 07:33 PM
