Help!! driver side axle popped out.
Old Oct 14, 2009 | 06:31 PM
RandomKoko's Avatar
Unhappy Help!! driver side axle popped out.
anyone can help me? what did you guys do? because i can't get the ball bearing into place. =( what was your experience because I am really sadden what happen.
i know there are threads about axle popping out. but can you tell me your experiences. thanks
Old Oct 14, 2009 | 06:50 PM
413FIT's Avatar
This happpend to me about a month ago when i was changing out my struts. just take the larger cv boot retaining ring out and slide the boot down and just play with it getting the cv joint back in the cup... i helping hand definitely makes it easier
Old Oct 14, 2009 | 07:06 PM
RandomKoko's Avatar
thanks for the fast reply.
are you saying cut the cv clamp? if i do that, how will the three ball bearing look like? how does it look like when they are apart?
Old Oct 14, 2009 | 07:22 PM
FitVic's Avatar
do what i did.
YOU wiggle the axle left and right.
have SOMEONE else turn the steering wheel all the way to the left and all the way to the right.
less than 5 minutes you'll get it.
I have done this with other fit owners and prove that it works quick lmao popped axles are nothing to me!
Old Oct 14, 2009 | 07:29 PM
RandomKoko's Avatar
^^ do you think that tripod bearing are remove? idk since it is on my driver's side. do i turn the steering wheel all the way to the left?
Old Oct 14, 2009 | 07:48 PM
FitVic's Avatar
you should be able to just turn it all the way to the left and to the right. I havent heard any problems about it.
Old Oct 14, 2009 | 07:51 PM
FitVic's Avatar
Just try it trust me. Have one person just turn the steering wheel back and forth all the way and i guess you would be wiggling the axle while pushing it in. Just move it around in different combinations and you'll get it. Put some muscle in it!
Old Oct 14, 2009 | 08:07 PM
RandomKoko's Avatar
damn it! it won't go in. sigh! i feel like dying (figure of speech). -_- seriously. =( ahhh!
Old Oct 14, 2009 | 08:27 PM
FitVic's Avatar
my method didnt work? or your not sure what i mean lol
Old Oct 14, 2009 | 08:44 PM
thefit09's Avatar
This happened to me, but only on the passenger side. I broke the factory clamp and slipped the cv boot off to see what I was working with. There are three bearings that have to line up exactly with the notches inside the axle. The bearings have to "push out" so to speak to fit in the notches and then it slides right back in. Make sure you repack with grease if you do end up pulling the boot off. There are special clamps to replace the clamp that you have to break. I got one from auto zone for 2.99. Make sure you don't use a hose clamp! Hope this helps!
Old Oct 14, 2009 | 09:12 PM
RandomKoko's Avatar
what did you use to break the cv clamp? because i do not want to break the cv boot that's why =(
Old Oct 14, 2009 | 09:17 PM
thefit09's Avatar
Wire cutters
Old Oct 14, 2009 | 11:12 PM
RandomKoko's Avatar
f***! haha i succeed! i remove the clamp and align the tripod bearing into the mounting axle whatever you call it. but now i need a good clamp in order to tighten the boot neatly.
Old Oct 14, 2009 | 11:16 PM
thefit09's Avatar
It feels good, doesn't it? Now get some grease and the clamp made for cv boots (at any parts store), and then repack the inside with grease and put on the new clamp.
Old Oct 14, 2009 | 11:21 PM
RandomKoko's Avatar
it does feel good, it seems i can't get the clamp to put together. it's too greasy outside the boot.
Old Oct 14, 2009 | 11:23 PM
thefit09's Avatar
Yeah, it takes patience. Maybe grab a shop towel and get as much grease off as you can.
Old Oct 15, 2009 | 01:34 AM
RandomKoko's Avatar
do you think zip tie will hold the boot in place? a substitute for boot clamp.
Old Oct 15, 2009 | 02:40 AM
thefit09's Avatar
I would NOT use a zip tie. It wouldn't be any better than the boot being on there by itself.
Old Oct 15, 2009 | 03:49 AM
RandomKoko's Avatar
haha i used zip tie with metal clamp. i also used zip tie because it hold on pretty tight and the metal clamp did not. i drove 2 miles came back and check the boot, no grease. =D
Old Oct 15, 2009 | 05:03 AM
HONDAMATIC's Avatar
i would go to an auto parts store and get a clamp, because i used hose clamps, zip ties you name it on my old truck and blew um apart fairly quickly.. but you might need the sardine can tool to install the clamp properly..
