wipers?
Old Oct 19, 2009 | 10:05 AM
ujaks's Avatar
wipers?
while i havet been everywhere im having a hard time finding replacements. help? which ones are ya'll using?
Old Oct 19, 2009 | 10:23 AM
Type 100's Avatar
I use Bosch wiper blades myself, 20"/15". Just the normal ones with the metal frames, not those fancy frameless ones. So far so good.
Old Oct 19, 2009 | 11:04 AM
Vanishing Point's Avatar
Still using the original wipers on my '09 Fit in combination with Aquapel windshield treatment. There are plenty of sources other than the dealer, just run a search.
Rain Repellent Glass Treatment - Aquapel Glass Treatment
Old Oct 19, 2009 | 11:11 AM
gd3vbp's Avatar
I went with OEM replacements. Takes about 5 minutes per wiper, you slide out the old and in with the new, best thing is they're only $5 each. Whenever I have a laundry list of parts to order I pick up a set so I'm not paying shipping on just wiper inserts.
Old Oct 19, 2009 | 02:33 PM
chinky's Avatar
funny. i did a somewhat extensive search for this last night. there doesn't seem to be a consensus on a standard upgrade for wipers. what i gathered was that the oem ones are just ok, but are bad below freezing temperatures. people who buy aftermarket ones find that they have to buy a shorter 14" blade for the passenger side otherwise it will wipe over the windshield. it appears that the oem passenger blade doesn't attach to the arm at the middle of the wiper.
Old Oct 19, 2009 | 07:43 PM
Type 100's Avatar
Where I'm from, the OEM replacement for Honda wiper blades - and a lot of other brands - are made by Denso and NWB (Nippon Wiper Blade). The Denso blades are actually just rebadged NWB items.
And yeah, they take less than 5 minutes to replace. Easy as pie.
Old Oct 19, 2009 | 08:30 PM
grtpumpkin's Avatar
Bosch Icons, and Rain X (of course) Advance Auto has em......
Old Oct 19, 2009 | 08:58 PM
bobek's Avatar
I just bought a set of wiper blades from Bosch, the 24" arm is fine, but like many others the 16" (passenger side) just barely fits. I've tried the Trico Neoform brand as well. Again, the passenger side is too long.
Old Oct 20, 2009 | 01:27 AM
Type 100's Avatar
Doesn't your wiper motor have a hard time with the longer blades? A friend of mine tried 22"/16" on his GD1 and his wiper motor slowed right down because of the weight and extra length.
Old Oct 20, 2009 | 01:40 AM
secondspassed's Avatar
Makes sense. Honda's only gonna pay for as much motor as they absolutely need for that application.
Old Oct 20, 2009 | 06:24 AM
bobek's Avatar
The OEM ones are 24" and 16" I think. The ones I bought seem to be the same length as the ones I replaced.
Old Oct 21, 2009 | 06:46 PM
vdot90's Avatar
Are those Rain X ones really better than the OEM ones? (I'm not really a big fan on OEM ones)
Old Oct 21, 2009 | 10:09 PM
seonadancing's Avatar
I want to get Bosch Aerotwin frameless wipers. I currently have some generic framless ones 22"/14"
Old Oct 24, 2009 | 11:38 PM
narquam's Avatar
Reviews on amazon are pretty mixed between blades. So I'm going to trust you people. How much of an improvement are the Bosch and are the Rainx any good? Anybody have Bosch Icons? My blades are way overdue for replacement.
Old Oct 25, 2009 | 12:00 AM
tanukifit's Avatar
I just found out the back wiper blade is the same as the 2007 Nissan Murano oem blade.
I bought oem replacement blades (rubber wiper only) for the front and back.
I'll buy the Murano complete back blade next time.
If any one finds a blade that mounts on the side like oem let us know. Michelin one works good but is ugly.............
Old Oct 25, 2009 | 12:13 AM
wdb's Avatar
wdb
I was using Anco's copy of the Bosch Icon but got tired of seeing those things jagging up in my lower windshield. So I got a pair of refills for the stock blades from Bernardi Parts, I think they cost all of $7 for the pair. They do a fine job with rain.
However. I have the 2008 wipers, which are rigid plastic frames with two hinged points about 1/4 of the way from either end. Those hinges froze up on me last winter, which caused that end of the wiper to cease to contact the windshield, which annoyed me greatly because it made a fine mess of my ability to see where I was going. I noticed that a friend's '07 had one-piece rubber-like blades; I may spring for a set of those if I experience freezing pivots again this year.
Old Oct 25, 2009 | 12:19 AM
TurboManGT's Avatar
I think I'm gonna try the PIAA wiper blades on my next replacement. Has anybody used them before?
Old Oct 25, 2009 | 10:51 PM
bobek's Avatar
Bosch Icons are alright. Maybe they're in the break-in period.
My gf digs the Rain-X ones though, and they seem to be doing a good job.
Old Oct 25, 2009 | 11:21 PM
im using factory refills. easy to replace and readily available...perfect fit each time.
Old Feb 4, 2010 | 07:09 PM
jeff618's Avatar
Lightbulb
Trico NeoForm Beam Blades on the front (26" drivers side and 14" passenger side). Trico Exact Fit Rear Integral Blade on the rear - 14". Got the whole set-up online.
