Snow tires again - Do I need front wheel caps, lug nuts and hubcaps?
Old Nov 4, 2009 | 06:38 AM
Black3sr's Avatar
I will be taking my Sport in to get the snows put on. My tire dealer stored them since last month when I bought them and had them mounted on Honda steelies.
Just wondering as can't recall what is behind the front Sport wheel. Their is an axle cap?
Do you use the Sport lug nuts or replace them?
What do you use for hub caps if any?
Will be interesting to see what the ride is like and what it looks like with black steels.
Old Nov 4, 2009 | 08:17 AM
Uncle Gary's Avatar
Personally, I think the car will look cool with black steel wheels-very "urban assault vehicle."
Old Nov 4, 2009 | 09:49 AM
Virtual's Avatar
I'll post my pic again:
As you can see, I used a center cap from by old Civic. The chrome lug nuts and lock are from the Civic too.
Those parts should be available quite cheaply at a scrapyard.
Old Nov 4, 2009 | 07:18 PM
hyperfit's Avatar
Do you know what the stock lugnut size is on an '09 fit?
Just getting outfitted with tools to swap my winter wheels and tires in.
Thanks
Old Nov 4, 2009 | 08:22 PM
Type 100's Avatar
Thanks
17mm hex, M12x1.5 I reckon. That's what I had on my GD; I don't think your GE's lugnuts will be any different. HTH
Old Nov 5, 2010 | 11:05 AM
ansl1's Avatar
What is the size of your steel wheels?
Hi,
What is the size of your steel wheels in the picture below? I need center caps for my Fit's winter wheels. They are 14-inch black rims. Yours look great with those caps.
[/quote]
Those parts should be available quite cheaply at a scrapyard.[/quote]
Old Nov 5, 2010 | 11:16 AM
Black3sr's Avatar
I painted my 15" and found some old caps I had to strip paint off. They are kinda ratty but better than none.
Size:  39.3 KBName:  0032.jpg
Old Nov 5, 2010 | 04:39 PM
Virtual's Avatar
Originally Posted by ansl1
Hi,
Those are my 15" Genuine Honda Fit rims. The center bore size should be similar to your 14" rims so the center caps might fit those too. In fact the center caps you see came from my old 88 Civic which had 13" rims. Try out a local scrap yard and ask if you can check fitment before purchase.
Old Nov 5, 2010 | 04:59 PM
jeff_1986's Avatar
Yea the Fit doesn't look too bad on steelies.. I like my winter wheels at least. Wouldn't mind grabbing some center caps tho.
Old Nov 5, 2010 | 07:17 PM
specboy's Avatar
Tomrrow I think I'm picking up a set of Integra 15" Mesh Wheels. $13 Each. going to use them for Winter Wheels. I'll need to pick up some center caps as they are coming with only 3 (1 honda, 2 acura).
I'm debating on putting some work into them to polish them up a bit. The clear-coat is rubbing off in some areas. Wondering if I should try and paint or just touch up.
oh wait... it's me... I have a 4 yr old... They'll stay the way they are likely.
~SB
Old Nov 6, 2010 | 05:03 AM
Black3sr's Avatar
If you find a source for center caps I sure could use 4 good ones. They do provide some protection to the front axle.
Old Dec 31, 2010 | 03:53 PM
huisj's Avatar
I recently got some steelies too through tirerack. I'm not too familiar with the old civic center caps, but I really like the simple finished look of the ones people have posted on here. I'm wondering if they'll fit on non-Honda wheels though? I did some measurements, and the center on my wheel seems to be the same as the specs I've found for some caps on ebay, but I'm still not gutsy enough to pull the trigger and buy them without knowing for sure if they'll fit. How do they go it? Do they just snap in place?
Old Jan 1, 2011 | 06:23 AM
Black3sr's Avatar
I went through same thing. I really can't help you. My Fit steelies have the center raised around the hole. My caps go over the outside of this. They have a ridge to the inside all the way round about 1/2 inch or so from the lip. It is this ridge that holds the cap on once it is driven on. I also added a couple wraps of black tape to the lip of caps as there is suppose to be a plastic of some kind on the lip I guess to prevent marking the wheel?
Best would be to try a junk yard. There may be some other caps that would work as well. Another option is the chaep plastic hubcaps. I used them the first winter - here is a pic
Old Jan 1, 2011 | 02:16 PM
inkster's Avatar
Markahm Honda has the same caps for sale. I didn't see how much they were though. Give them a call or your local dealers.
subicraze
Jun 1, 2015 06:16 AM
knm345
Apr 20, 2013 05:26 PM
lowkeymods
Feb 25, 2012 02:19 PM
mike410b
Oct 11, 2011 05:11 PM
Necos07
Jul 25, 2009 03:37 PM
