Fit's engine in Formula F..finalized
Old Nov 6, 2009 | 11:09 AM
Fitcious's Avatar
I guess this is finalized..Fit's engine in Formula F.
SCCA approves Honda Fit-based engine for Formula F — Autoblog
Old Nov 6, 2009 | 11:12 AM
Fitcious's Avatar
^does this mean more performance parts for the fit?
Old Nov 6, 2009 | 11:21 AM
dewthedew's Avatar
learn to read. they are keeping the engine stock.
Old Nov 6, 2009 | 11:34 AM
Fitcious's Avatar
alright. i think my 4 year college degree has taught me that, wouldnt you? and when i asked my question, i meant for possible fit performance part in the future for the GE.
no need to be a dick about it
Old Nov 6, 2009 | 12:39 PM
Kurse's Avatar
The L15 from Toda engine is built for the same thing
Old Nov 6, 2009 | 03:46 PM
eldaino's Avatar
is there a need to bring up your 'college degree' everytime someone says something to you? pfft.... please man.
Old Nov 6, 2009 | 04:17 PM
Probably not...
I see where your coming from since even on a stock engine the shape and size of exhaust can dramatically change the output of the vehicle... but can't really apply the cart's design since the shape of the cart and Fit is so different...plus the legality issues of emmissions, noise, so on so forth.
Old Nov 6, 2009 | 04:43 PM
TurboManGT's Avatar
I too have noticed an increase in people bringing up their educational background lately
Old Nov 6, 2009 | 04:53 PM
Well, I can tell you that unless you have a 4yr college degree (minimum) you won't be allowed to work in the core team where I work, but that 'degree' sure don't mean anything for some of them. LOL! :D
Old Nov 6, 2009 | 06:07 PM
Fitcious's Avatar
correct me if im wrong, but i believe this is the first time i ever brought it up. you might mistaken me for someone else.
also, im not bringing it just for the heck of it. but dewthedew states that i need to learn to read and i figure that my 4 year degree has taught me that.
i was just commenting on his comment. no biggie. and i agree with kenchan...4 year degree doesnt mean much now...masters ftw.
Old Nov 9, 2009 | 12:14 PM
BlueCell's Avatar
I saw the engine at SEMA. I talked to the guy, its still a GE8 stock 119hp but improved oil pan, transmission plate for different drive, and new intake manifold.
Pictures I took.
Old Nov 9, 2009 | 05:53 PM
DrKelso's Avatar
lol. The phrase "learn to read" rarely means that you literally need to " l e a r n t o r e a d "
Rather, he was implying that had you actually utilized the vast knowledge that you had gained during your 4 years at whatever prestigious university from which you hail, you may have been able to detect (through various complicated forumulas and algorithms) that the motor which they will be using is a relatively un-modified version of the L15A7.
and just to put a hole in your logic. dewthedew stated they were keeping the engine stock. How would Honda (in conjunction with the SCCA) building >>stock<< L15's equate to the influx of more performance parts for the GE8?
Old Nov 9, 2009 | 08:11 PM
dewthedew's Avatar
I said "learn to read" because..
Original equipment in the 2009 Honda Fit, the L15A7 is a fuel-injected, 1.5-liter, overhead cam engine, at the beginning of its current production generation. Per Honda corporate policy, a minimum of 10 years' parts support is mandated at the conclusion of production.
HPD will supply all parts from intake through exhaust, including multiple chassis conversion kits. The result will be a modern and reliable engine requiring minimal maintenance and tuning.
Specifically, HPD expects to offer FF competitors the opportunity to reduce their engine operating costs. Engine rebuilds will be reduced, while competitors should also experience a reduction in the need for top-end refreshing. In addition, crankshaft and valve-spring life should be extended dramatically; and most ignition and all carburetor maintenance will be eliminated.
They're keeping it cheap/mostly stock to keep it fun. You dont need more than 120hp in those chassis anyways.
Old Nov 9, 2009 | 08:54 PM
Gbaby2089's Avatar
having a 4 yr. degree most definately does not mean that you are smart........anyone can get a degree if they can afford it and want one........i've met some dumb people with degrees and some very smart people without them
Old Nov 9, 2009 | 10:26 PM
DrKelso's Avatar
^^ Troof :gangsta:
Old Nov 10, 2009 | 01:32 AM
kingofpicklez's Avatar
Zomg you guyz has da college duhgreeez?
Old Nov 16, 2009 | 10:23 PM
dtmbmw325i's Avatar
What about the guys with the doctorates and masters degrees that can't figure out how to control the tv with a remote or figure out anything with a simple bit of common sense....
or is that just ignorance to get people to do stuff for them? Making 100K they shouldn't have to do too much. But I digress...
Old Nov 16, 2009 | 10:43 PM
Perrenoud Fit's Avatar
Officer, I can't see over the intake....sir
Hey guys who makes a hood to cover the intake? Thankz for the pix BlueCell...............Cya'll
Old Nov 17, 2009 | 12:01 AM
DrKelso's Avatar
This engine will be sitting behind the driver. You see that scoop just above where the driver's head will be? That's the intake.
Old Nov 17, 2009 | 07:43 PM
Texas Coyote's Avatar
The Fit shares one more thing besides a cult following with the VW Beetle.... The SCCA had the Formula V Class powered by stock Beetle engines many years ago.
jazzivtec
Nov 9, 2014 03:53 PM
MMurray
Oct 8, 2010 03:49 PM
Spooling
Jul 21, 2009 10:54 PM
Midnightfit
13
Apr 21, 2008 09:46 PM
Injundon
Oct 9, 2007 02:26 AM
