Turbo Engine stall for 3 to 4 sec
Old Mar 9, 2010 | 06:21 AM
clanbuster's Avatar
Running L15A for almost 2 year with TD04.
All the sudden this problem started since 2 week ago and till can't slove.
Example: When step hard from speed 30 mph, ( didn't full floor it)
the engine RPM cannot move up. My AFR gauge show 15.2 + - 1
I think either too much air or fuel but i didn't do any adjustment on piggyback until this 2 week. I had change spare plugs and same result.
Could it be the fuel pump cannot deliver amoung of fuel into engine?
2 year old pump need to change/upgrade?
Old Mar 9, 2010 | 10:36 AM
NIGHTHAWKSI's Avatar
running too lean (too much air).
stock fuel pump? what injectors you running?
id say yea, time to replace it. get a walbro.
Old Mar 10, 2010 | 07:42 PM
clanbuster's Avatar
I was thinking walbro too. but what will be the pressure setting?
Same as usual 50 PSI or increase it?
Old Mar 10, 2010 | 07:45 PM
clanbuster's Avatar
beside fuel not enough, is there other reason?
As u know, AFR Gauge not accurate as the digital always ratio different ratio at every sec. Sometime my eye see until blur.
loudbang
14
Dec 30, 2013 12:07 AM
soesja
Aug 13, 2010 01:19 AM
clanbuster
Mar 18, 2010 02:45 PM
clanbuster
Mar 16, 2010 12:20 PM
clanbuster
Mar 11, 2010 12:20 AM
