View Single Post
  #5 (permalink)
Old 05-04-2005, 05:44 PM
Randolph
Guest
Posts: n/a
Re: door lock remote doesn't work after stereo upgrade
MinnesotaMike wrote:
> After upgrading the stereo system in our 97 Civic HX, the remote door
> lock control will not work. There was two parts to the original stereo
> system. One was up by the heater controls and the CD player was down by
> the cup holder. I have checked the fuses, under the dash, but they are
> all okay. Any reason why this would happen? Any suggestions on what to
> check? Everything worked before the install so I'm a little lost right now.
In the 1996 - 1998 Civic, the receiver for the keyless remote was
integrated into the factory stereo. If you replace your stereo with an
identical Honda unit, you will have to reprogram it to match your keys,
if you replace it with an after-market unit (or a Honda unit that does
not have the receiver in it) your keyless remote will not work. Your
dome light probably stopped coming on when you open the doors? It is
wired through the stereo as well.
There are several work around:
1. You can wire the new and the old stereo up at the same time and hide
the factory stereo behind the dash / center console (yes, it will fit!).
See http://tinyurl.com/4zbuc (leads to http://www.installdr.com) If you
do this, the factory stereo gets all connections except the speaker
wires, the new stereo gets all the wires except the keyless entry wires.
Do a search for "Civic Relocation harness" and you will find
ready made harnesses that will allow you to do this. I know Scosche
makes them. Remember to keep the front panel from the factory stereo;
You will need it if you ever need to reprogram the keyless entry
receiver.
2. You can install a new after market keyless entry system like
http://tinyurl.com/3eb77. (Part number 330-145 from
http://www.partsexpress.com). This is a complete keyless entry system
for $40. You will have to use the new key chain transmitters that come
with the unit, the original Honda key fobs will not work (try it anyway,
there is a small chance you can program the BW850 unit to receive the
Honda keyfob signal). This system
does everything the original factory system does, including priority
unlock (driver's door only on first press, all doors on second press,
feature can be programmed on or off) and dome light control (need an
additional relay, e.g. http://tinyurl.com/34457 at $1.19). It is easy to
install, as all the wires you need are available on the plug that went
into the factory stereo. If you go this route, post a real e-mail
address, and I can send you a wiring diagram. I have installed two of
these before.
A very modest collection of Honda tech info can be found at:
http://www.geocities.com/ng_randolph
