Scangauge and A/C?
Old Jun 15, 2008 | 07:07 AM
ezduzit's Avatar
Scangauge and A/C?
I have a Scangauge but it's not in my Fit right now because I sent it in to be upgraded to "X" gauge.
My question is whether the Scangauge mileage readout changes when you turn on the A/C?
Does the Scangauge display actual mileage or is it just an estimate based on engine size, throttle position, previous tank entries, etc,?
Old Jun 15, 2008 | 08:20 AM
pcs0snq's Avatar
Yes expect a big jump down on MPG and GPH when you turn it on. That will improve as you drive. I have commented on that in SG Schooling a few times. AC uses gas for sure.
Old Jun 15, 2008 | 12:12 PM
ezduzit's Avatar
I know turning on A/C uses gas, I just didn't know if the Scangauge reflected that change in the display when you turn it on.
thanks!
Old Jun 15, 2008 | 04:03 PM
wdb's Avatar
wdb
Yes.
If you're talking about the realtime MPG reading, it is a calculated value: MPH / GPH.
Old Jun 15, 2008 | 04:22 PM
ezduzit's Avatar
Originally Posted by wdb
Yes.
Ok, but is the calculation based on actual fuel flow, engine loading, throttle ,etc., or is it just an estimated calculation based on engine size, type (4 cyl, 6 cyl, etc).
I'm wondering because in the setup you have to enter that data, and then you have to "accurize" the realtime MPG reading by entering in fuel usage after several tankfuls.
Maybe it's based on both realtime measurements and previously entered data and I'm just having a hard time getting my head around how it works?
fitchet
Dec 16, 2017 02:53 PM
Sprocket
Dec 2, 2013 01:18 AM
Odie
May 11, 2011 02:14 AM
Blackbeard
Mar 16, 2011 12:00 AM
Gamin
Dec 31, 2008 09:05 AM
