Fit FREAK.net
Go Back   Honda FIT Forums > The Honda Fit and Jazz Forums > Eco FIT
Eco FIT Fit for Fuel! Got the low mileage blues? Care to share a 40+mpg tale? Automatic vs. Manual? Come here to discuss topics on fuel efficiency and other Green Topics
Reply
  #1 (permalink)
Old 05-21-2008, 06:25 PM
Senior Member
Fray Adjacent will become famous soon enough
Fray's Summer Tips
Summertime is upon us! This usually means reduced fuel economy due to having to use the AC frequently. There are a few things we can do to help reduce it's impact on our fuel economy.
1. Get your windows tinted! Use a good quality metallic film, and go with either the darkest you can stand, or the darkest legal in your state. Use a reputable installer. (I recommend the 3M metallic films. I've had it on several cars and it looks great and performs well.)
Tinting your windows will help reflect heat and UV rays that not only heat up your interior, but also degrade your upholstery, plastic and leather components.
2. Get a sunshade and USE it! This has the same affect as tinting - it helps keep the interior from getting so hot, and also shades your dash, protecting it from UV rays. I'd try to find a reflective or light colored shade that fits the window well.
3. When possible, keep a couple windows open just an inch. This will help the cabin vent hot air
4. When starting your drive, roll down your windows, and set the AC for fresh air. Windows down will get that hot air out of your cabin. Setting the AC to fresh will pull in air from outside that is likely cooler than the inside temperature at first.
5. After a few minutes driving, roll up the windows, but leave the AC on fresh for a little while longer. When the air output is cool enough, switch to recirculate. This lets the AC work on the now cooler inside temperature.
6. Reduce fan settings as you are comfortable. The more you reduce the fan, the lower the duty cycle of the compressor will be, easing the load on the engine.
These are a few things I've learned over the years. Living in Texas, it gets mighty hot during the summer months. I've tested and found the sunshade and tint tips can keep your car's interior about 20 degrees cooler. It'll still get HOT, but not AS hot.
And I think this is my 'FitFreak mantra'...
Remember... the biggest thing that affects your fuel economy is
YOU
__________________
My other TWO cars are PORSCHES
2001 Porsche Boxster
1969 911T Targa - "Stinky"
Fray: a usually disorderly or protracted fight, struggle, or dispute
Adjacent: not distant, immediately preceding or following
Sponsored Links
  #2 (permalink)
Old 05-21-2008, 06:30 PM
JDMchris.com's Avatar
Administrator
JDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to liveJDMchris.com relies on Rep Points to live
good thread!
__________________
KillerFit #8)
AIM: JDMCHRISDOTCOM
07 TW KWSC'd
08 SSM Daily
Yes I have 2 Fits!
KRAFTWERKS Kit Owner #1
Can't wear skinny jeans cuz my nuts don't fit
EPIC BUILD
No hassle 09 Fits at MSRP- PM me
  #3 (permalink)
Old 05-21-2008, 06:47 PM
pcs0snq's Avatar
Frequent FitFreak Poster
pcs0snq will become famous soon enough
I'd like to add a few.
Get window vent/shades and you can leave the windows cracked with no fear of car flood
If there's a spot in the lot that has shade from something, use it. That's BIG for initial comfort and save the chepo Honda paint from UV.
pic of window vent/shaded
__________________
Paul
2008 VBP Fit Sport Man 5 spd trans
Over 114 gal's saved in the last 10,000miles
  #4 (permalink)
Old 05-21-2008, 06:58 PM
FITrunner's Avatar
FITrunner is a jewel in the roughFITrunner is a jewel in the roughFITrunner is a jewel in the rough
My parents are all about the friggin home shopping network and those "as seen on tv ads". They bought one of those solar car fan/vent things that hang on to your window when you leave them cracked open and the blow the hot air out of your car. They actually do work (a little). He's got two that he uses on his Lexus. I borrowed them to test it on my Fit. However I realized that my windows are tinted too dark for the solar panel to get enough juice.
Oh yeah one thing I did notice, is that if its really hot, say in the 90's, they do absolutely zero in my honest opinion. Because at those temps I usually dont sit in an idle car long enough to actually measure if they are helping or not, hot is hot. I get moving to get a breeze going ASAP or I turn on the AC. If anything they help keep the air circulating, so maaaybe its not stale. Other than that, its a novelty item.
__________________
VBP Honda Fit (The daily driver) ,
White Full Size Mitsubishi Montero 4x4 (The camping and playing in the snow car) ,
Formula Red Acura NSX (The garage queen)
  #5 (permalink)
Old 05-23-2008, 03:36 AM
Blaw's Avatar
Blaw will become famous soon enough
Thanks for the post.
What kind of sunshade are people using or recommend for the Fit?
It seems like my sunshades are easily worn from use...and i end up with ugly torn shiny blobs that just sits in the back seat.
__________________
  #6 (permalink)
Old 05-23-2008, 12:11 PM
Senior Member
I got one off of Amazon... it's one of those wire rimmed cloth jobbers that you twist into a little circle to 'fold' up. I think it's a large. The Fit does have a HUGE front window, so you'll need something BIG. I'll check Amazon and see if I can find it.
I think this is the one I got: Amazon.com: Basix Magic Jumbo Sunshade (Styles May Vary): Automotive
__________________
  #7 (permalink)
Old 05-23-2008, 09:48 PM
Deanwvu will become famous soon enough
I have never tried this sunshade, but I love the concept!
It is quickly deployable and always handy---you cannot lose it!
The only problem is I don't see a version for the Fit yet... maybe another model could be used?
Dash Designs
  #8 (permalink)
Old 05-27-2008, 04:33 PM
dyussen is an unknown quantity at this point
I've an accordion style shade that has a scrunch silverfoil layer on either side. Simply unfold and flip down your visors to hold it in place. It has an elastic loop that goes around it to hold the bunch together and you can just toss it in back when driving (make sure it's out of sight; the reflection from the sun on the foil could unexpectedly blind you). I don't think these are more than 10 bucks at your favorite Target.
__________________
Proud fit owner since Nov, 2007.
  #9 (permalink)
Old 05-27-2008, 09:26 PM
Senior Member
Quote:
They're very cheap, and VERY effective at helping keep the car cool inside. I'm stunned by how many cars I see around here sitting in the hot sun... no tint, no front sunshade... I'm pretty religious about using my sunshade. I put that bad boy in when I get home from work at 10:30PM, so the car won't be so hot when I leave for work the next day at 12:30PM.
__________________
  #10 (permalink)
Old 05-29-2008, 02:22 PM
K LoLo is on a distinguished road
What size sun shades are yall using for those accordian style ones?
  #11 (permalink)
Old 05-29-2008, 02:29 PM
Quote:
I don't think mine came with any choices of size. It is a little too wide thanks to the the Fit's narrowness but the edges just hang down and block some sun from the side windows - bonus!
__________________
Reply
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
East Coast End of Summer Party. ChrisG Off Topic Discussion 0 09-27-2007 12:45 AM
End of Summer Meet Idea DynamicFit California - Southern Community 19 09-03-2007 11:03 AM
Summer hike in prices? jquan23 Honda Fit Dealer Reviews 4 07-08-2007 09:26 PM
Summer tires in the winter months? leonine General Fit Talk 12 06-13-2006 12:08 AM
Subcompact Demand Tips Scales to Japan FaceYogurt Front Page News 5 12-25-2005 12:57 PM
Go
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
