Mugen Style Front Grille
Old Aug 10, 2007 | 09:33 AM
mugenfit79's Avatar
Originally Posted by i-Fit
really? but the seibon grill i have fit great without cutting the middle part. coz the grill is pre shape to fit in
Nope not this one. It was designed as though there is no plastic pillar going down the middle of the grill opening. It looks like I might to get a dremmel tool...
Old Aug 10, 2007 | 09:43 AM
jdmparts@gmail.com's Avatar
Originally Posted by 07fitsport
wanted to know how do you remove the stock grill and also where can you get a seibon grill for the fit..
For a Seibon grill check out iptuned.com one of our sponsors:
https://www.fitfreak.net/forums/fit-...eibon-fit.html
As for installing any grill:
Old Aug 10, 2007 | 09:54 AM
mugenfit79's Avatar
Perfect, if you were to look at illustration 2 and 4 above you can see the center pillar I am having trouble with in the bumper part of the grill opening where the H emblem goes... I saw that seibon does have it so it wraps around that pillar without having to cut it out.
Old Aug 10, 2007 | 10:21 AM
Yea the Seibon grill has a notch in it to wrap around the center pillar.
Since this Mugen style grill is ABS plastic, a dremel or small saw would take care of it. Just use painter's tape to mask the area first before cutting, this will produce a cleaner cut and also lessen the burring effect (the cut surface spreading up & down) when cutting plastic. I would paint the center pillar black so it's not as noticeable.
Old Aug 10, 2007 | 10:33 AM
mugenfit79's Avatar
Thank you for the tips. Any idea what I can use for a template? Or I guess I will have to do it by eye.
Old Aug 10, 2007 | 10:35 AM
i-Fit's Avatar
i installed my grill without remove the bumper. but u have to be careful tho
Old Aug 10, 2007 | 10:37 AM
mugenfit79's Avatar
Same here I just took out the 2 wheel well screws and the top bumper clips and popped it down. I still would be careful doing it that way....
Old Aug 10, 2007 | 10:54 AM
Illusive's Avatar
So are you gonna mod the grille to fit? Sounds like the best way to do it is to eyeball it. Make sure you don't cut out too much. Do it little by little, as you can always remove, but can't put back...pics when it's done please !
Old Aug 10, 2007 | 11:23 AM
mugenfit79's Avatar
It looks like I will have to mod it. I will do it this weekend when I get some time.....
Old Aug 11, 2007 | 01:38 PM
Yea just trim away a little bit at a time, you can always sand just a little bit more off but can't add material back.
To achieve an even radius, use a can to trace the outline so the curvature is even throughout the cut.
Old Aug 13, 2007 | 01:02 PM
Illusive's Avatar
So? Any updates?
Old Aug 14, 2007 | 10:26 AM
  #32
mugenfit79's Avatar
So? Any updates?
Sorry man, not yet. I will try to get to it this weekend. I want to take my time on this one....
Old Aug 20, 2007 | 04:05 PM
  #33
Illusive's Avatar
BUMP! Any updates?
Old Aug 26, 2007 | 07:27 PM
  #34
i-Fit's Avatar
bumpy bumpy@@@@
Old Aug 27, 2007 | 11:03 AM
  #35
Illusive's Avatar
I'm in contact with Speed Fiends to see if they can get them as well.
Old Sep 7, 2007 | 05:16 PM
  #36
i-Fit's Avatar
bumpy bumpy
Old Sep 7, 2007 | 05:57 PM
  #37
Illusive's Avatar
I'm out of this one, just got the J's Grille from AJ
Old Oct 14, 2007 | 12:45 PM
  #38
smeister's Avatar
Any update yet???
Old Dec 6, 2007 | 04:49 PM
  #39
lidoshorty02's Avatar
i had to cut the middle part and then used double sided tape
Old Dec 6, 2007 | 05:36 PM
  #40
JaySmith's Avatar
Any pictures of the entire front end? I'm liking what I'm seeing.... but would probably opt for Seibon.
