Fit FREAK.net
Go Back   Unofficial Honda FIT Forums > Fit Trix > Fit Interior Modifications
Welcome to Fit Freak!
Welcome to Fit Freak,
Reply
  #1 (permalink)
Old 11-19-2006, 04:01 PM
gettinafit will become famous soon enough
Talking VTEC Light for USDM FIT Completed!
Hey everyone!!! Great NEws!! I just installed a VTEC light on my M/T Fit Sport. I will take video footage of the engagement and disengagement points ASAP. It's cool!! And it looks nice! And now I can save more gas by keeping it out of VTEC on the highway! Sorry I'm starting a post without the pics, I was Freezing outside here in NY today temp is like 40 F!! Pics and Report Soon, stay tuned!!
__________________
ImportFest 2007
http://www.fitfreak.net/forums/car-s...tml#post196608
Sponsored Links
  #2 (permalink)
Old 11-19-2006, 04:24 PM
sy11580's Avatar
sy11580 is a splendid one to beholdsy11580 is a splendid one to beholdsy11580 is a splendid one to beholdsy11580 is a splendid one to beholdsy11580 is a splendid one to beholdsy11580 is a splendid one to beholdsy11580 is a splendid one to behold
what is that? How can you do it? It is very interesting. Show me picture and video!!!
Can AT intall it too???
__________________
My Fit is RED !!!
Member of NEFC & Fits In Tune
  #3 (permalink)
Old 11-19-2006, 05:47 PM
Video is here!! Tutorial on how our VTEC works in our cars! http://www.zippyvideos.com/6312989636305026/p1010280/
Here's one that you can't see the Tachometer, but it is Wide open throttle after engaging the clutch nicely (rpms low start not a dump da clutch start)
http://www.zippyvideos.com/3110179146305426/p1010281/
http://www.zippyvideos.com/5319936356308386/p1010285/
Gotta go to 5:00 Mass. More tomorrow! Enjoy
__________________
ImportFest 2007
  #4 (permalink)
Old 11-19-2006, 05:49 PM
Vtec Engages at 3400 RPMS only if you are accelerating pushing the gas like a feather weight! Otherwise at 2300 RPMS, On comes VTEC! Anywhere between 2300 and 3400 if you are off the throttle it will turn off, once you get back on it, it will come on again! I really gotta go to church!
Bye!
__________________
ImportFest 2007
  #5 (permalink)
Old 11-19-2006, 05:57 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
sLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to livesLiVeRwOrM relies on Rep Points to live
Send a message via AIM to sLiVeRwOrM Send a message via MSN to sLiVeRwOrM
where did you get it?!
__________________
If it moves, try to race it. If not try to eat it.
  #6 (permalink)
Old 11-19-2006, 06:20 PM
sy11580's Avatar
I think I need a morning shot!!! So dark in the video!! but I'm very interested on it!!!
__________________
My Fit is RED !!!
  #7 (permalink)
Old 11-19-2006, 07:00 PM
I made it with a 12v relay, and an Led bulb and socket, resister, and a wire tap, and lots of wiring.
I tapped into the VTEC solenoid B+ wire out of the PCM (Powertrain control module) Green wire with Yellow strip connector B.
I took apart the drivers' instrument cluster and other paneling, drilled a 1/4 " hole for the LED socket, and wired it up behind the dashboard tieing up the wires with Tie-wraps. Of course soldering all connections! (All for under $30)
IT's nice, there is also a slight audible click from the power relay when VTEC engages and the signal is sent to the light bulb.
More info on how the car operates tomorrow as I drive it some more and take nitice of things. As well as daytime pics and more videos! Stay posted!
__________________
ImportFest 2007
  #8 (permalink)
Old 11-19-2006, 07:28 PM
Yes Any one can add a VTEC light too!
__________________
ImportFest 2007
  #9 (permalink)
Old 11-19-2006, 07:33 PM
sy11580's Avatar
let me check it out in our meet!!!
__________________
My Fit is RED !!!
  #10 (permalink)
Old 11-19-2006, 08:00 PM
Someone that Posts too much
sillypuddy is on a distinguished road
can you take a picture of the ecu wire?
-joe
__________________
JDM+
  #11 (permalink)
Old 11-19-2006, 08:17 PM
Sure can, Actually I will probably be performing this on another Fellow Fit-freaker's ride on the board some time soon, I'll make a Do-it-yourself (DIY) thread.
The PCM can be found by the passenger foot. basically looking up inside the dash from underneith to the "right" of the glove box. I will take this pic and post it tomorrow.
__________________
ImportFest 2007
  #12 (permalink)
Old 11-19-2006, 08:24 PM
thanks a bunch..
do you think the relay was necessary?
previously others (on civic forums) just hard wire the LED to the same pin
-joe
__________________
JDM+
  #13 (permalink)
Old 11-19-2006, 08:35 PM
sy11580's Avatar
I'm in I'm in!!! I will do that as a demo car for the pictures!!! hohohoh
__________________
My Fit is RED !!!
  #14 (permalink)
Old 11-19-2006, 08:39 PM
Hard wiring is not a good idea b/c now you are powering the Vtec solenoid and your VTEC light off of the PCM's power..... if something goes wrong with the wiring (Custom ) behind the dash and it shorts to ground, we are frying the PCM with out the relay!
Using a relay we are supplying the LED bulb with it's own power source and using the PCM Vtec wire as a signal more than anything else!
Best to use a relay! It's only $3-5 bucks for a standard 12v Automotive relay.
__________________
ImportFest 2007
  #15 (permalink)
Old 11-19-2006, 08:43 PM
Sure man, call me, we'll setup a time to do it!
__________________
ImportFest 2007
  #16 (permalink)
Old 11-19-2006, 08:45 PM
hmm.. but if the signal wire falls off the relay, it's the same thing no?
-joe
__________________
JDM+
  #17 (permalink)
Old 11-19-2006, 08:54 PM
sy11580's Avatar
well, I'm good on Tues 11/21/2006 or Sunday 11/26/2006 (If you don't need to go to ski). Time ........... same as last time 1:30pm. Will it take long? Let me know if you can!!! Thx.
__________________
My Fit is RED !!!
  #18 (permalink)
Old 11-19-2006, 10:39 PM
aziatiklover's Avatar
Master FitFreaker
aziatiklover will become famous soon enough
Send a message via AIM to aziatiklover
congrats man
__________________
  #19 (permalink)
Old 11-19-2006, 10:54 PM
Wave's Avatar
Wave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to liveWave relies on Rep Points to live
Guess we can always slap one in my car too (along with the rear strut tower bar, "Home Depot Ram Air", and soon to be forced induction system from ???)
__________________
  #20 (permalink)
Old 11-20-2006, 12:04 AM
Quote:
-joe
I did not disconnect the the car's harness wiring. I just mearly tapped into it with a squeeze tap and some 18 guage wire from that to the relay. So car's harness is in fairly no danger of becoming disabled.
__________________
ImportFest 2007
Reply
Tags
add, civic, cluster, diy, fit, freaks, gauge, honda, indicator, install, installation, led, light, sport, vtec
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Go
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
