Cutting springs
Old Jul 19, 2009 | 01:36 AM
FLFIT239's Avatar
hahaha do it brotha
Old Jul 20, 2009 | 12:37 PM
Jackson's Avatar
You have obviously already made up your mind about cutting the springs but I still want to add that it is a bad idea and very unsafe. You really don't want to compromise the saftey and reliablity of your suspension for aesthetics.
Old Jul 20, 2009 | 12:40 PM
FLFIT239's Avatar
haha well its to late and yes i alreadt knew this thanks though
Old Jul 21, 2009 | 03:04 AM
BlahhblaBlahh's Avatar
So how exactly did you cut it since the spring is narrow at the top, gets fat towards the middle, and gets narrow again at the bottom?
Old Jul 21, 2009 | 03:21 AM
FLFIT239's Avatar
i was told always cut from the bottom so i just took a coil off the back from the bottom and half a coil from the bottom of the front springs
Old Jul 21, 2009 | 03:40 AM
how does it sit? I would assume not too stable since it needs to be narrow towards the bottom to sit on the strut
FLFIT239's Avatar
its still pretty narrow mine sits fine no problems so far atleast
Old Jul 21, 2009 | 03:43 AM
so you cut your stock springs? or did you cut lowering springs that werent low enough?
hows the ride? FAIRLY decent? cause i mean, of course its not going to ride good since theyre cut springs.
Old Jul 21, 2009 | 03:51 AM
FLFIT239's Avatar
i cut the lowering springs cause they werent low enough
and ride is bumpy and not the best but thats expected and i think it was worth the drop
Old Jul 21, 2009 | 03:56 AM
what lowering springs are you on?
Im currently on skunk2 springs and debating on whether or not to cut them.
Old Jul 21, 2009 | 08:33 AM
FLFIT239's Avatar
im on eibach sportlines B1str0 has cut both skunk2's and eibach sportlines pm him
Nikoatnite
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Feb 3, 2015 06:54 PM
iLUVYOURGE8
Jun 18, 2009 06:09 PM
Fitting
SoCal Classifieds
May 15, 2009 04:34 PM
SNOW
Feb 10, 2009 08:03 PM
davinabretina
Mar 24, 2008 05:54 AM
