Suspension Issue - DF210
Old May 31, 2007 | 11:48 AM
joe d's Avatar
I installed Tanabe DF210s a couple days ago and I'm getting an issue with knocking.
I'm getting a knock on the drivers side front, and it *seems* to be centered around the sway bar (I think that's what it is - the bar with the boot that connects to the upper portion of the strut) - right at the point of connect.
Any ideas what could be causing it/how to fix it?
Trying to avoid bringing it in, but I'm getting the feeling its inevitable.
Old May 31, 2007 | 01:17 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
knocking, it could be a loose bolt, sometimes I hear squeeking when I go over bumps and things on my GF210s but that is just the spring or shock..
Old May 31, 2007 | 11:33 PM
WhatFreshHell's Avatar
knocking like this is about 98% some bolts aren't tight enough. I would triple check every bolt before you do anything drastic.
Old Jun 1, 2007 | 02:04 PM
aallbbeerrtttttt's Avatar
My DF-210's have given me no problem at all, probably installation error on your part
Old Jun 1, 2007 | 08:07 PM
MyOtherCarsANinja's Avatar
Something is loose. If you didn't do the work then bring it back to whoever did and explain that you would like to get the suspension checked. If it is an installation problem on their part you should demand to have it done for free. If there is something wrong outside of the installation then the bill will fall on you. Good luck.
Old Jun 1, 2007 | 08:53 PM
koolkevin1107's Avatar
hmm....is it while just normal driving or hard driving. did u cut the bump stops? tanabe instructions says cut it from 15-25mm's. I cut mine 20 and have never hit them so i'm assuming they were cut perfect.
marcn24
Aug 10, 2016 07:22 PM
AnlDyxp_GD3
18
Nov 3, 2008 07:56 PM
pastadog
Feb 28, 2008 03:24 PM
gthumb23
Jan 8, 2008 05:09 PM
fit4kris
Tanabe Racing Development USA
17
Oct 16, 2007 12:19 AM
