heater problems
heater problems
well got in my 08 fit sport tonight the first time ive driven it in cool weather and the heater doesn't work. i'm so pissed its not funny the blower motor works and everything else works. i'm at a loss for what it could be the antifreeze level is ok no fuses blown just when i turn the knob to heat it only blows cold air anyone else had this problem? oh it has the stock head unit too i'm going to try and get it to the stealership in the morning and i hope they don't have to tear apart my dash to fix it. edit: the a/c button is off.
Noticing the same thing. Started a thread here for some input: https://www.fitfreak.net/forums/2nd-...tml#post480612
See you went to a Honda dealership and they fixed the problem. Can you elaborate on EXACTLY what was the issue? I'm booking an appointment for this week and it would help alot if I knew what was fixed on your car. Thanks!
What caused the problem?
Thanks! I've got a couple of plausible explanations but end result is I should book my car in ASAP! Calling now. +Rep to you. Hopefully this IS a quick/simple fix. Just 6 weeks on my car now....
the linkage pegleg is talking about is the linkage us stereo folks undo when we
remove the stock HU. i was about to post 'check linkage' but noticed he already
got the problem solved.
the linkage problems does not appear to be consistent with fitcanadagirl's
because she's getting heat, but it dissapates sitting idle.
if the linkage was broken i think she would either get heat or no heat or just
no control of the heat.
i think it has something to do with the coolant level/cooling system for her.
M4psycho offered the following: "
I was just doing some investigation myself on the web, since I wasn't 100% convinced about the thermostat being the culprit. It looks like this is a common issue if there is air in your coolant system/not enough coolant fluid. This prevents good circulation while you're idling 'cause either air is blocking the way or there's not enough fluid to flow through the heater core (when you're idling). This isn't a problem when you're moving because everything is forced through quite nicely. To remedy this you can bleed out the cooling line while topping it off while the car is idling. (Open the rad cap, idle the car for 5-10 minutes and keep topping up the rad fluid until it doesn't drop anymore).
Of course the thermostat can be an issue too if it's "sticking"....but apparently that would cause a cycle of hot-warm-hot-warm rather than cold, 'cause your engine shouldn't cool off *that* quickly when idling.
Things are starting to make a bit more sense! I can't guarantee that all of the above is 100% true but that's all I've got right now. "
I'm booked tomorrow at 2h30 PM at my Honda dealership so will let them do the fiddling. I'll update everyone once they figure out the problem/resolution....
Problem (maybe) resolved!
Ok, just got back from 2 hours sitting at the Honda dealership. I explained my exact issue with the heating system. They ended up "bleeding" the block heater. Exact words on my invoice are:
OPS10 BLEED THE SYSTEM ALL OK
4ITECH 1.20
,,,,,4191 no heat repaired b.h added new a/f
So, end result was an issue with my freaken block heater! For back story, the first remote starter they installed ended up being defective and I went 5 DAYS without my car (driving an '09 LX loaner) while they ordered/installed a second unit. Not having much luck with darn accessories!
Small consolation that it was NOT a problem with the car itself or the coolant system...phew! Can't test today since it is freakishly hot around here and will be so for the rest of the week. I'll report back if the problem is REALLY fixed once we get back to normal temps around here...
4ITECH 1.20
