drop springs or full suspension..
Old May 9, 2009 | 04:17 AM
  #61
showcaseGD3's Avatar
i met the two guys(silver ones) who autocross.... not sure if they were on skunk2's
Old May 10, 2009 | 06:47 PM
  #62
enjoito's Avatar
one is on skunk2 and the other on t1r
Old May 10, 2009 | 10:57 PM
  #63
kingsize's Avatar
randy aka "raton" has the pro-c's on. i think he got his pretty cheap online somewhere..
08fitsport has the T1R springs and dampers like me.
Old May 10, 2009 | 11:11 PM
  #64
die_lawn's Avatar
Does anyone have issues with their drop springs making noise or is it just me? I'm sitting on tanabes GF210 right now
Old May 10, 2009 | 11:47 PM
  #65
enjoito's Avatar
i telling u have to break in lol.. but might be something else try look in suspension section.
Old May 10, 2009 | 11:49 PM
  #66
HONDAMATIC's Avatar
mine never made noise, ever
Old May 10, 2009 | 11:53 PM
  #67
da loose nut behind da wheel
Old May 11, 2009 | 03:25 AM
  #68
tanukifit's Avatar
Make sure you tightened that top hat down before putting em in and recheck the the top nut after mine didn't seat right until few hard turns.
Old May 11, 2009 | 04:30 AM
  #69
kingsize's Avatar
if its a klunking noise, make sure all your nuts are on tight. i had this issue in the rear. idk about springs making any noises though..
Old May 11, 2009 | 04:38 AM
  #70
enjoito's Avatar
cheee! 4 hour instal for me!
Old May 11, 2009 | 03:19 PM
  #71
tanukifit's Avatar
That's pro action!!
Old May 11, 2009 | 03:46 PM
  #72
enjoito's Avatar
na cause the axle pop out...
Old May 11, 2009 | 03:50 PM
  #73
tanukifit's Avatar
That means you would have finished in 2 hours. you da man!!
Old May 11, 2009 | 07:42 PM
  #74
die_lawn's Avatar
Haha yea mines popped out too but took me 2 hours total including that haha.. But anyways, I have everything tightened down to the max. I dunno what else it could be, but it's kinds irritating
Old May 11, 2009 | 08:11 PM
  #75
tanukifit's Avatar
Is it in the front or back? Is your jacks tools and stuff floating by the spare tire loose stuff in the glove compartment.
Old May 11, 2009 | 08:14 PM
  #76
die_lawn's Avatar
it's my fronts that's making the noise..
Old May 11, 2009 | 08:33 PM
  #77
tanukifit's Avatar
top hat, top bushing snug against the chassis, anti roll bar tight hmm
is it when your rolling and turning? cv joints? tie rod ends? axle went in smoothly? lug nuts tight?
Old May 11, 2009 | 08:53 PM
  #78
die_lawn's Avatar
yeah everything is tight.. It's only when I hit small bumps in the road that it has the clunking noise..
Old May 11, 2009 | 09:26 PM
  #79
tanukifit's Avatar
It really sounds like the nut that holds the spring down (top hat) before you put the strut in the car.
Is the top of the nut to top of the strut same on each side?
Past threads about noise included endlinks for the sway bar simple test take the noisy side off and test.
Old May 11, 2009 | 10:08 PM
  #80
die_lawn's Avatar
hmm well would not cutting the bump stops have anything to do with this, like as in the strut and spring can't compress as far as it needs to?
