drop springs or full suspension..
Old May 11, 2009 | 10:39 PM
  #81
tanukifit's Avatar
Nah, the bump stop is just there so your suspension won't bottom out with a metal to metal clank but if that top hat is not all the way tightened when you hit a small bump the play in the strut top hat will meet causing a small clank sound. If you used an impact to tighten the hat down the driver itself will bottom on the top of the strut and won't tighten it all the way down. You have to use that allen and an open end till it stops.
Old May 11, 2009 | 10:44 PM
  #82
die_lawn's Avatar
Yeah I did mines with all hand tools and i'm pretty sure it's all the way tight, maybe I need to check them again
Old May 12, 2009 | 03:25 AM
  #83
808duece's Avatar
which side front or back?...
sorry...
my friend had the same problem so what for the back...
so what we did is just a little grease so that it stop making noise...
so far its been great to him no noise...
Old May 12, 2009 | 03:29 AM
  #84
HONDAMATIC's Avatar
maybe the spring isnt seated right..
Old May 12, 2009 | 03:54 AM
  #85
die_lawn's Avatar
It's the fronts. I just looked at them the other night and it looked fine. But maybe I just need to check them again
Old May 12, 2009 | 04:12 AM
  #86
enjoito's Avatar
yea brah!!!!!!!!!!!!!!!!!!!!!
Old May 12, 2009 | 01:52 PM
  #87
randay's Avatar
my skunks make noise when i switch from drive to reverse and vice versa. my rears made noise when i first installed, just rotated the spring a little and it went away.
Old May 12, 2009 | 09:43 PM
  #88
enjoito's Avatar
hmm yea that might help alot when i installed mine i made sure it sat right so i didnt have to take it off again and go through hell again..
Old Jun 4, 2009 | 09:24 PM
  #89
tanukifit's Avatar
Did you ever find out where the noise was coming from?
Old Jun 4, 2009 | 11:40 PM
  #90
die_lawn's Avatar
I believe it was my bump stops that needed to be cut
Old Jun 5, 2009 | 12:09 AM
  #91
tanukifit's Avatar
that's good to know, cool glad you got it fixed
Old Jun 5, 2009 | 01:15 AM
  #92
enjoito's Avatar
hmm weird cause i didnt cut mine at all and its fine
Old Jun 5, 2009 | 04:30 AM
  #93
tanukifit's Avatar
must have been a loose top hat bolt
Old Jun 5, 2009 | 04:35 AM
  #94
enjoito's Avatar
hmm i think soo. die_lawn should try see if its loose
Old Jun 5, 2009 | 04:41 AM
  #95
tanukifit's Avatar
I think he killed two birds with one stone by taking em off and cutting the bump stop then reinstalling.
Old Jun 5, 2009 | 04:51 AM
  #96
enjoito's Avatar
well i dunno then cause when i rode with u man weird bump noise..
Old Jun 5, 2009 | 05:11 AM
  #97
tanukifit's Avatar
that was some loose screws in the head
Old Jun 5, 2009 | 05:19 AM
  #98
HONDAMATIC's Avatar
got plenty of those at work, also 'whining noises behind the wheel'
Old Jun 5, 2009 | 05:24 AM
  #99
tanukifit's Avatar
And the stink seat cushions damn, dead animals.
boricuawarior
Mar 4, 2013 06:49 PM
chris_kosmic
Mar 24, 2010 05:53 PM
jurassicJAM
Apr 17, 2009 03:59 AM
08fithappy
Oct 7, 2008 06:24 PM
