honda accord engine problem
Old May 4, 2005 | 11:16 AM
dexue
Guest
Posts: n/a
I own a 99 honda accord. I don't have problem with for almost 6 years.
Today, when I started engine in parking position, I heard some strange
noise, sounds like sudden accelerations, tachometer goes from 1000rmp
to 2000rmp than drops back to 1000rmp, going back and forward. I
thought something wrong with gas pedal. Then I drived it around, the
engin noise grow louder.
Does this indicate a big problem with the engine?
Thanks,
-James
motsco_ _
Guest
Posts: n/a
Re: honda accord engine problem
> Thanks,
> -James
Check the oil level, see if the rad is full, and the reservoir should be
full to the line. Check back if anything isn't where it should be.
'Curly'
td
Guest
Posts: n/a
I agree check all the fluids levels first.
I would also check airflow sensor which should be somewhere by the air
filter and idle control sensor I am guessing by the air intake
manifold.
I can't really give you good locations but I am sure you can find it
fairly easy if you look up in manual.
I own Honda now but my previous car had rough idle and rpm fluctuation,
cleaning (very careful) airflow sensor with of "windex" and idle
control sensor with contact cleaner solved the problem (all lot of
carbon buildup).
Good luck, hpe it helped
mmdir2002@yahoo.co.uk
Guest
Posts: n/a
Are you driving a modified honda?
Guest
Posts: n/a
dexue
Guest
Posts: n/a
No, it is not modified honda.
dexue
Guest
Posts: n/a
Thanks all of you, I followed your recommend. I found the problem and
fixed it. It was the tube connecting the reservoir to the radiator
loosing up, prevent coolant circulation.
Now The engine runs smoothly again. :-)
Thanks again,
-James
sdn09fit
Aug 28, 2011 12:39 AM
Grahame
Aug 26, 2005 01:47 PM
Fijoy George
Jul 24, 2005 11:53 PM
DesignGuy
Jul 20, 2005 01:35 PM
Al Franz
Jun 27, 2005 10:39 PM
