Re: 2001 Accord EX brake light on dash
Old Jul 29, 2005 | 02:32 AM
Doug McCrary
Guest
Posts: n/a
Charlie S <chasa@rcn.com> wrote in message
news:ulaje1lbmahlfa1ejvfm69k4arm1lhavm3@4ax.com...
> If you are talking about the "brake light" at the Door and Brake Lamp
> Monitor, it's a burned out tail light. Honda brake lamps are special
> so buy "Honda" lamps at AutoZone or whatever auto shop you go to.
I keep seeing this -
"Special"? How? If the number is right, the lamp is right. Correct me if I am
wrong.
Old Jul 29, 2005 | 09:30 AM
motsco_ _
Guest
Posts: n/a
> wrong.
That's right. Honda tranny fluid is 'special', but a brake lamp is a
brake lamp. Honda doesn't manufacture brake lamps.
'Curly'
Old Jul 29, 2005 | 03:32 PM
Doug McCrary
Guest
Posts: n/a
motsco_ _ <"motsco_ _"@interbaun.com> wrote in message
news:42EA2E53.7090609@interbaun.com...
am
> > wrong.
> 'Curly'
Thanks, Curly.
Old Jul 30, 2005 | 01:21 AM
Charlie S
Guest
Posts: n/a
Honda installs a relay in series with each Tail Light Bulb so the bulb
sees less than 12 volts. I did not intend to say that you have to buy
a bulb manufactured by Honda. A bulb intended for other than a Honda
would fit, but not have the correct brightness.
For other than a Honda tail light, if I had a burned out bulb I would
look in a box in my garage for a bulb that looked the same and it
would work.
Cheers
Charlie
On Fri, 29 Jul 2005 18:38:53 GMT, "Doug McCrary"
>am
>> > wrong.
>> 'Curly'
>Thanks, Curly.
Old Jul 30, 2005 | 04:59 AM
Doug McCrary
Guest
Posts: n/a
news:14tle1dthbehe3fbo44j0a0sqqoiplhqk1@4ax.com...
Not.
Spec'd lamps are standard. A 327 or whatever has a specified voltage, base
design, current rating, and output (candlepower) .
Honda can't change that unless they design their own lamp, with their own specs
(and number). I don't see where they have done that. If you have an example,
please post it.
> would work.
> Cheers
> Charlie
Old Jul 30, 2005 | 11:01 AM
jim beam
Guest
Posts: n/a
eh? that's a new one on me! how does a relay drop the voltage to a
bulb??? by how much???? what's the purpose???
> would work.
> Cheers
> Charlie
>>>>news:ulaje1lbmahlfa1ejvfm69k4arm1lhavm3@4ax.co m...
>>am
>>>>wrong.
>>>'Curly'
>>Thanks, Curly.
Old Jul 30, 2005 | 12:30 PM
Casey
Guest
Posts: n/a
Huh? A relay is just an on/off switch.
Casey
Old Jul 31, 2005 | 01:32 AM
Charlie S
Guest
Posts: n/a
It's not a relay Contact in series with each Tail light bulb it's a
relay COIL. A COIL has a voltage drop so I assume 9 volts on the wire
between the relay and the bulb.
This is not new Honda has been doing this for over 10 years.
I remember going in to Kragen's and being told that Honda has
different Brake lights than other brands.
4 of the 5 Brake lights are dual filiment.
I have a '92 Accord wiring diagram in front of me and I can see the
relays.
On Sat, 30 Jul 2005 07:26:28 GMT, "Doug McCrary"
>news:14tle1dthbehe3fbo44j0a0sqqoiplhqk1@4ax.com.. .
>Not.
>please post it.
>> would work.
>> Cheers
>> Charlie
Old Jul 31, 2005 | 03:44 AM
Doug McCrary
Guest
Posts: n/a
news:lvjoe1pcbcjn2bgbgctmfqc846iudqi0m4@4ax.com...
Not a valid assumption. The effective resistance of the lamp would be around 6
ohms for a 27W stop lamp. I'm sure they've made the relay to be around .5 ohm or
less, so the voltage at the lamp would be closer to 12v in a real-world 12.8 -
13.5 volt world. It'd be interesting if you could actually measure one of the
relays, and/or the voltage across it and/or the lamp(s) in your car.
I believe it.
I believe this too, but I also believe whover told you that is/was full of it.
Immaterial. As I understand so far, the relays are in the brake lamp circuits.
Presence of a tail light or whatever in the same lamp envelope is of no concern.
> relays.
No doubt. Probably the other responders misunderstood the discussion so far.
Is there a part number for the relay on your car? Maybe I can find the specs.
Googling is good, but in this case I'm either not coming up with the correct
search parameters, or there's just too much stuff...
Old Jul 31, 2005 | 11:32 AM
jim beam
Guest
Posts: n/a
you /assume/ a coil has a voltage drop of 3V??? what's the resistance
of the coil in proportion to the bulb??? the math is real simple.
dude, /no/ manufacturer puts a relay coil in series with a high wattage
bulb. period.
no. get the bulb number and cross reference it against all the other
applications - it's just a stock bulb used industry-wide.
so? it's called redundancy. it helps keep the car safe when neglectful
drivers fail to check to see if their bulbs are working properly.
> relays.
i have two different helm [honda factory] circuit diagrams in front of
me right now, and there are no relay coils in series with any light
bulbs. there must have some sort of problem with the drawings you have
if you think you're looking at relay coils.
>>news:14tle1dthbehe3fbo44j0a0sqqoiplhqk1@4ax.com. ..
>>Not.
>>please post it.
>>>would work.
>>>Cheers
>>>Charlie
Old Jul 31, 2005 | 12:31 PM
Grahame
Guest
Posts: n/a
Dude, I have the 90-93 Accord Haynes repair manual wiring diagram in front
of me and there is a device called a brake light sensor which uses what's
called a reed relay. There is a relay in series with each brake lamp, when
the lamp is on the current travelling through the relay pulls in a contact
which tells the monitor that the lamp is working. If the bulb is burned out
(open) then no current flows through the relay and the contact remains open,
indicating a brake lamp is out by the brake lamp on the dash.
"jim beam" <nospam@example.net> wrote in message
news:esWdnZG8kZOrcXHfRVn-qA@speakeasy.net...
> bulb. period.
> > relays.
> >>Not.
base
own specs
example,
> >>please post it.
> >>>would work.
> >>>Cheers
> >>>Charlie
Old Jul 31, 2005 | 06:45 PM
SoCalMike
Guest
Posts: n/a
doesnt the symbol for "light" look like a coil of wire in a bulb? mebbe
TE cheah has morphed?
jim beam
Guest
Posts: n/a
and the bulb current is not conducted by the coil, it's conducted by the
reed. that's why there's no voltage drop.
>>bulb. period.
>>>relays.
>>>>news:14tle1dthbehe3fbo44j0a0sqqoiplhqk1@4ax.co m...
>>>>Not.
> base
> own specs
> example,
>>>>please post it.
>>>>>would work.
>>>>>Cheers
>>>>>Charlie
misfit83
Aug 3, 2008 09:44 AM
motsco_ _
Jul 28, 2005 11:08 PM
Greg
Jul 28, 2005 06:34 PM
Jason
Jun 3, 2005 01:06 AM
Joe M
May 4, 2005 11:16 AM
