1998 Accord - Engine Shuttering
Old 09-17-2005, 04:43 PM
Erick Larin
Guest
Posts: n/a
On my 1998 Honda Accord 4-Cyl, my engine starts to shake/stutter when I'm
in 4th gear (automatic) usually between 1600-1900 RPM's. If I force the engine
to downshift, it goes away. I also started to smell a little gas vapor coming
from my vent right around the same time this started happening. It's faint
and I can only smell it when the car is not moving. I don't smell it with
the A/C on.
So far, I've replaced the spark plugs and wires and distributor cap and rotor.
I've also gotten the timing belt package replaced. Again, this started before
I did any of this stuff. I looked into replacing the fuel filter but the
1998 Accord has it built into the fuel pump so I don't think that's it.
Other than this annoying things, the car runs smooth. I have no idea what's
wrong. Can anyone suggest something? Thanks!
Erick
Old 09-18-2005, 07:30 PM
Steve
Guest
Posts: n/a
Re: 1998 Accord - Engine Shuttering
I can't explain the gas smell but I can suggest that you check the vacuum
advance. This is an "Old Tech" problem but that is what I found wrong with
my carborated '85 CRX CVCC. ]
Just to look and all those hundreds of vacuum hoses and different components
is intimidating, however, from years of old, low tech, cars I started with
the obvious and after finding one broken vacuum hose and then both diaphrams
in the vacuum advance leaking, the engine hesitation went away.
My experience and opinion, FWIW
Steve
"Erick Larin" <thelarin@hotmail.com> wrote in message
news:532a7232342f8c789b009887567@news.east.cox.net ...
> engine to downshift, it goes away. I also started to smell a little gas
> vapor coming from my vent right around the same time this started
> happening. It's faint and I can only smell it when the car is not moving.
> I don't smell it with the A/C on.
> rotor. I've also gotten the timing belt package replaced. Again, this
> started before I did any of this stuff. I looked into replacing the fuel
> filter but the 1998 Accord has it built into the fuel pump so I don't
> think that's it.
> what's wrong. Can anyone suggest something? Thanks!
> Erick
Old 09-19-2005, 03:31 PM
ClubPlug.net - Your Source for NGK & DENSO Spark P
Guest
Posts: n/a
Hi Erick
I have to agree with Steve, 99% of the times if the engine
"shake/stutter", it is cause by a leaking vacum hose. Many times you
hear people saying that they changed a gas regulator or changed the gas
pump, etc.. However, while they change these parts, many mechanics
will also change the hoses and 99% of the time it was the hose that was
at fault.
Unfortuantely, it's easy and quick fix, the problem is finding the
leaking hose.
Good luck.
Frank
Old 09-19-2005, 04:32 PM
Erick Larin
Guest
Posts: n/a
I have no idea where the vacuum advance is in the engine. Where is it usually
located?
> vacuum advance. This is an "Old Tech" problem but that is what I found
> wrong with my carborated '85 CRX CVCC. ]
> components is intimidating, however, from years of old, low tech, cars
> I started with the obvious and after finding one broken vacuum hose
> and then both diaphrams in the vacuum advance leaking, the engine
>> I'm in 4th gear (automatic) usually between 1600-1900 RPM's. If I
>> force the engine to downshift, it goes away. I also started to smell
>> a little gas vapor coming from my vent right around the same time
>> this started happening. It's faint and I can only smell it when the
>> car is not moving. I don't smell it with the A/C on.
>> and rotor. I've also gotten the timing belt package replaced. Again,
>> this started before I did any of this stuff. I looked into replacing
>> the fuel filter but the 1998 Accord has it built into the fuel pump
>> Erick
Old 09-19-2005, 05:30 PM
Misterbeets
Guest
Posts: n/a
Motor mounts or transmission problem. If it only does it in 4th it
can't be an engine problem.
And you have a gas leak from the fuel supply or evap recovery system.
Old 09-19-2005, 10:43 PM
CR50HC's Avatar
Possibly a CV Axel joint sticking as well. I had a vibration at certain speeds that troubled me for a long time. Turned out to be a bad cv outer joint on the passenger side.
Old 09-20-2005, 11:32 AM
Steve
Guest
Posts: n/a
It is on the Distributor (where all the spark plug wires go). It is attached
to the side and is usually a round can shape with one or two vacuum hoses
going to it.
Steve
news:da6aafe005738c78b4151042b9b@news.east.cox.net ...
>usually located?
>>> Erick
Old 10-01-2005, 05:31 PM
Erick Larin
Guest
Posts: n/a
I jumped the service connector today and am getting the following error codes:
71
73
74
What does this mean?
> force the engine to downshift, it goes away. I also started to smell a
> little gas vapor coming from my vent right around the same time this
> started happening. It's faint and I can only smell it when the car is
> the fuel filter but the 1998 Accord has it built into the fuel pump so
> Erick
R. P.
05-03-2006 09:23 AM
jostorama@gmail.com
10-17-2005 10:32 PM
Fijoy George
07-24-2005 11:53 PM
kirkstinson@hotmail.com
06-16-2005 01:37 PM
justice01812
05-04-2005 11:16 AM
Quick Reply: 1998 Accord - Engine Shuttering
