Rims&Tires&Rubbing .. oh my.
Old Jul 7, 2008 | 12:45 PM
SHG_Mike's Avatar
Originally Posted by mahout
The difference in distance from the hub face for a 195 tire on 39mm offset rims is half the tire section width less the offset, or 97.5 - 39 = 58.5mm. But you can't use 39 mm offset for 205 tires. Rubs.
a 195 tire on a 45 mm offset is 97.5 - 45 = 52mm. There's your 1/4" difference. Its not the wheel but the tire position that matters. The wheel and tire centerlines are set by the offset.
BTW A 205 tire on 42 yields 60.5. On 45 its 57.5. 205 on 39 is 63.5 mm and it rubs unless the tire is significantly smaller diameter than 23.4".
The blanket statement covers the widest tires on the widest known rims, aka '7', knowing anything less will fit too.
Ok i see what your saying, but i think it would be very close to fitting with a 205, the tire type also has a play in it with how wide or square the tread blocks are etc. With camber i think a 205 would be fine.
About that lip like others said, NO WAY would that fit.
Old Jul 7, 2008 | 01:48 PM
MNfit's Avatar
Thanks for the info guys, its a big help. I think im still going to go for it and get the lips and see what happens
Azizul Zulzaha
Mar 22, 2011 01:01 AM
mdsniper7
Oct 16, 2010 04:19 PM
korky
Jun 4, 2008 03:33 AM
FITGD3
Jan 21, 2008 07:00 AM
jdmjazz
Feb 17, 2007 03:20 PM
