wheel alignment help
Old Jan 20, 2008 | 11:07 PM
FitnessJay's Avatar
hey whatsup guys
i had recently purchased my hnda fit about 4months ago
2 months into it i bought eibach springs sportline kit once i bought them i did not get a tire alignment and thats where the trouble started
im not an expert on hondas so i didnt know to get my tires aligned
anyways i went for a COUPLE WEEKS on the new springs and they wore my tires all the way down to bald and you could see the metal popping through
i decided to drive home from work from la to antelope valley through the crest which is about 60 miles and my left front tire popped
long story short had to buy 2 new front tires and new alignment ended up costing me like 300 to 400 dollars something like that
but they could not align the back for some reaspon so they just told me they would align the front
so i think i need a camber kit for my fit to fix all the problems and get everything back to normal anybody know where i could get one from
thankyou very much
sorry if my story is hard to understand but i just wanted to get it out there
dont forget to get your car aligned!
Old Jan 21, 2008 | 02:55 AM
ilovemyGD3's Avatar
thanks for the heads up! i need an alignment, probably gonna get one this week!
Old Jan 21, 2008 | 03:51 AM
SPON FIT's Avatar
you cant adjust the rear and they should be able to align the front without the need for a camber kit
Old Jan 21, 2008 | 04:46 AM
claymore's Avatar
Correct you can't adjust the rear but with lowering springs installed in the front there is not enough adjustment in the stock suspension to align the front. You need to get the eccentric bolts and even they may not be enough to align the font with other than stock springs installed.
Old Jan 21, 2008 | 10:17 AM
SPON FIT's Avatar
the bolts only allow you to adjust the camber which isnt bad enough to cause tire wear issues
Old Jan 21, 2008 | 10:34 AM
FitnessJay's Avatar
awesome guys thanks for the input im pretty much just wanting my tires to last as long as they can cuz its not fun buying brand new tires for a car youve only had for a couple months hahaha
i got the fronts aligned but they said the rear cant be dont but it isnt that bad
wouldnt getting a camber kit help out anyways to make your camber that much better?
im not a genius with this stuff just asking questions=]
Old Jan 21, 2008 | 11:04 AM
ToyotaLover's Avatar
camber isn't what causes your tires to wear so quickly it's toe.
When you lower your car you steering rack pushes out the wheels from the back making your toe in front point inwards. Driving for a long duration of time like that will cause your tires to go bald. Hence why you should align your car regardless of what type of car if you played with the suspension.
Old Jan 21, 2008 | 01:18 PM
jeffquach's Avatar
post pics, i want to see the sportline drop.
Old Feb 10, 2008 | 06:24 PM
You didn't tell enough about what drop you did but here goes some advice:
1. You can adjust the rear alignment using shims between spindle to axle hub face.
2. Did you adjust the toe on the front after dropping?
Camber just as quickly wears out the tire as bad toe setting; likewise caster will too.
Redd
May 14, 2015 09:00 AM
stalonehong
Jun 7, 2011 01:17 AM
jondotcom
Mar 26, 2010 12:01 AM
Luichenwai
Jan 16, 2009 04:27 PM
henryd1981
27
May 17, 2008 04:16 PM
