tuneable with boost?
Old May 26, 2008 | 11:43 AM
dman77fb's Avatar
is it possible to do a little more of a custom tune with the kwsc/hondata injector upgrade? i'm sure the upgrade is great, but a one-size-fits-all tune doesn't seem to make much sense. can it be combined with e-manage, or a similar fuel management system in order to hone in for your specific set up?
dave
Old May 26, 2008 | 12:20 PM
underdog's Avatar
I may have miss understood it but if it comes with hondata it should be fully programable? most factory tune's are generic so that it can be installed in the 120 degree deserts all the way up to the 7000+ft elevations with below freezing tempratures and not blow up. so there is usally alot of power left in the tune its self. especially with a speed density system(map based management)
correction on the hondata. its just a re-flash so you would not be able to re-tune unless you were at an otherized dealer.
dewthedew
Jan 28, 2010 10:42 AM
sbualuba
Jan 4, 2010 12:26 AM
OJRKraftWerks
Nov 2, 2009 06:18 PM
YeeFit
232
Jun 14, 2009 01:17 PM
GTP
40
Apr 25, 2008 12:07 PM
