vtec solenoid cleaning... do we need to do it?
Old Jul 23, 2008 | 11:03 AM
gofastredfit's Avatar
From: Hampton Roads, V A U.S., Earth, Milkyway Galaxy
Question vtec solenoid cleaning... do we need to do it?
I've heard of other people w/ vtec cleaning their vtec solenoid every 12k miles & was wondering if that is something I should be concerned about?
Old Jul 23, 2008 | 12:16 PM
straw's Avatar
I clean my vtec every morning in the shower...
Old Jul 23, 2008 | 03:35 PM
Can I get a real answer??
Old Jul 23, 2008 | 03:42 PM
Fit_to_be_tied's Avatar
i have never done it or heard of it being done
Old Jul 23, 2008 | 04:25 PM
Ditto, never heard of it being done either.
Is it in the owners manual?
Old Jul 23, 2008 | 04:52 PM
its not part of any honda service
Old Jul 23, 2008 | 11:00 PM
This is what made me wonder...
(yes I know that this isn't the same motor as ours but it's vtec)
DIY: vtec solenoid cleaning
Old Jul 23, 2008 | 11:47 PM
The hell? Why are these people saying their cars have more power uphill by cleaning the solenoid
the first time i did mine on my old motor, there was so much build up. after i changed it, vtec hit so damn hard! i had forgoten that it was supposed to feel like that.
How the hell can Vtec hit harder? lol
Correct me if I am wrong, but it has a pretty simple function;
The solenoid pops out and changes the timing by engaging a second set of rockers at a pre-set RPM by the computer. Unless it is stuck (in which case Vtec would not engage and I am sure the ricer boys would be sh!tting themselves) then this makes no sense... there is no "performance" advantage to clean it unless it is flat out malfunctioning.
Maybe, just maybe it reduces the time it takes for the solenoid to pop out... but like by fractions of a second.
Old Jul 24, 2008 | 02:47 AM
fork_nSpoon's Avatar
not necessary at all. Looks liek a bseries motor. Replace filter only if you see oil leaks.
Old Jul 24, 2008 | 08:42 AM
The guy that posted it was trying to convince me that I needed it ... and this being my first vtec engine wasn't sure... that's why it was so important to get input from my fitfreak bros. & sisters!
Rob
Old Aug 7, 2008 | 06:23 PM
polaski's Avatar
With previous Hondas--
I've had the gasket leak between the passages to the point that vtec wouldn't engage when the computer told it to, all pressure just bled between them. That motor had 140k miles and 10 years of hard use on it at the time.
I've had the solenoid stick ON, yeah that wasn't fun, 1500rpm idle on an auto FTL. That motor was only 4 years old with about 80k miles.
--relevant info---
Never seen shavings make it past the filter up to that gasket screen. Maybe by some turn of bad luck you get an oil filter that doesn't have the filter media sealed, you might have to clean the gunk out of the screen.
Rule of thumb-- if vtec isn't working, you'll know it because it will fall fat on its face before redline (esp. "vtec-e" 12v when it's not working like the L15A1). If it's working, don't mess with it because its really too easy to snap off the bolts that hold the solenoid valve to the head and really too hard to get the bolt ends OUT.
--ok that's all for on-topic---
As for how "hard it hits," or more accurately how quickly the lifters lock, that is pretty much constant. Whether it works at all is determined more by oil pump wear, main/ rod bearing wear, how quickly the filter can pass oil after the pressure drop, and what kind of oil you use (high-viscosity additives in high-mileage oils tend to slow up the works in my experience). A motor with good bearing clearances and a good pump usually won't care what kind of filter and oil you use; a motor with worn bearings and an old pump will probably need a filter with a bypass valve as well as non-"75000+" mile oil to work quickly. I know, my old tired y8 wouldn't lock the valvetrain without that combo. Even with a K&N oil filter, on max life oil the engine would need to be at 2000 rpm or more for at least 5 seconds before accelerating so the ECU would see the 65psi at 5500 rpm that it requires, so in 1st gear it only rose to about 60psi because it didn't have the time. Switch to regular oil, same viscosity, 70 psi in 1st.
Helps to have an oil pressure gauge sometimes.
Two weird vtec behaviors that only occurred once on that motor--
Once, a single lifter locked to the high rpm lobe and didn't unlock until I shut the car off. That was a FUNKY idle.
Accelerating onto the highway, vtec engaged, disengaged, then engaged again before I upshifted. ECU saw the pressure drop.
Old Aug 7, 2008 | 06:42 PM
polaski's Avatar
Since I have a feeling this would have started into debate anyway
As for sound change, if the engine is tuned perfectly with the vtec crossover where it should be (low-cam torque matches high-cam torque), since torque is in indication of volumetric efficiency at a particular rpm, the transition would be almost if not inaudible.
With low-high lobe vtec engines like b16a/b18c#/k20a-2 /k24a /d15b vtec /d16z6-y8 series, it can be audible from the difference in the low cam lobe duration to the high lobe duration. Greater difference in duration, greater sound change. On a disabled-valve type vtec like the d16y5/k20a3/k24a2/L15A1 the duration is the same on low- and high-rpm vtec modes so the change isn't so pronounced soundwise.
Aftermarket intake typically has the effect of leaning out the A/F mixture on any honda engine save the MAF-equipped ones (no the L15A1 does not have a MAF sensor! the k20z1 in the new Si does though). This tends to lower the best vtec transition rpm, so when it occurs "late" on the stock ecu it makes more sound (valvetrain suddenly got efficient again) as well as bumping torque in a hurry. That's why my old y8 would start spinning in the rain at 5500rpm 1st gear on cheap tires after the cai was installed. Really too bad, if the car had a chipped ecu with a good tune, and vtec engagement was lowered to the proper point it would have that higher torque number earlier, with smoother delivery.
Free-flowing exhaust quiets vtec transition noise from the intake and makes it more audible through exhaust, and conversely excessive backpressure makes intake noise the loudest thing in town, but who wants the lack of power and the blown headgaskets.
Old Aug 8, 2008 | 09:56 AM
Good info & insight thanks for posting!
Old Aug 13, 2008 | 10:40 PM
randomracer's Avatar
okay looking to find this out for a long time but where is the vtec solenoid and can i put one of those cool skunk2 caps on it??
Old Aug 14, 2008 | 07:01 PM
explosivpotato's Avatar
lol.
..lol.
Old Aug 14, 2008 | 10:03 PM
polaski's Avatar
LoL x2
Front right corner of the cylinder head... it has the solenoid and oil pressure sensor on the valve assembly.
Where the heck would a cap go, it's using engine oil, there's no additional fluid of any type...
Old Aug 14, 2008 | 10:10 PM
Originally Posted by polaski
LoL x2
it was a jk but skunk2 makes a cover for it to make it look cool..
Old Aug 22, 2008 | 04:04 PM
Saved's Avatar
Damn ricer j/k
Seryoga1
Nov 28, 2010 03:47 AM
nmfit2008
Sep 22, 2009 10:39 PM
tonyd3773
Feb 9, 2008 12:03 PM
der Mond
Feb 3, 2008 12:18 AM
